Jul 14, 2019, 02:33 AM
Yeah i will probably have to de-solder the flash chip and rewrite the content of it.
Anyone has some high res image of the pcb before i take the camera modul apart?
Jul 17, 2019, 03:22 PM
jno
jno
I'm bored.......
for that reason in 30 minute and fast bi-component glue I have build this adaptor
for recharge 3 battery in the same time.
( the best recharge is done ever at 0,5C on all LiPo cells, in this case 900 mAh 6S battery )
Jul 18, 2019, 02:30 PM
What height will the Bugs 5W fly to when starting RTH? It's not stated in the documentation and I can't find it anywhere.
Jul 18, 2019, 08:21 PM
John Luciano's Avatar
Every quad I have will fly to 60 feet if it is less than that when it is RTH. and more than 20 Meters away. I guess Bugs same
Jul 19, 2019, 11:45 PM
BigRHS's Avatar
I have had my Bugs 5 for about 3 weeks now and it has flown great with the exception of a couple of times and tonight was one of those times.
It did a flyaway on me. I lost control and had to hit the lock button to shut the motors down before it hit my home. Before that happened, I had been flying for around 8 minutes or so, and I decided to land it, basically doing a touch and go and took off again without shutting it down and I took it up to about 20 meters and was going to do a few laps around the yard and all of a sudden off it went on it's own.
I could not get control of it and like I said I had to hit the lock button and shut the motors down and of course it dropped like a rock.
It broke the mount on the bottom for the camera but the camera was alright and one of the little rubber damping balls was lost but other than that it's good.
I took the camera off and got another battery and flew it again and it flew great.
What in the heck would cause that ? That makes twice now. I make sure I follow the startup and calibration steps so I just am at a loss.
Could it be some type of interference ?
I would appreciate any help and was wondering if anybody else has had that issue ?
Jul 20, 2019, 12:13 AM
Intermittent Wi-Fi interference could be a possibility. BUT...
We don't have the 5W yet but have several 2W/Cs and I think they all have similar characteristics. 2 possibilities...1 You have an intermittent fault somewhere in the quad's (most likely) wiring or .....2 Are you waiting for the quad to fully acquire satellite lock before you lift off? The Bugs quads can fly with no initial satellites but since the home point is set at the point where the quad acquires minimum satellite lock (6 or 7) and at any subsequent motor arming point. Thus if you take off and fly to hover over a 60 meter high tree and the quad THEN acquires the requisite satellites, when the low battery RTH kicks in if you are near the ground the quad will rise to 20 meters and head straight for that tree. Hope it's the latter 'cos intermittent faults are sheer hell to find and fix!
Best of luck.
Jul 20, 2019, 09:14 AM
Originally Posted by jno
I'm bored.......
I suggest that you get another hobby... You're dangerous when you are bored.
Jul 20, 2019, 03:02 PM
BigRHS's Avatar
Best of luck.
Thanks for your reply oztreecrasher.
I always wait to take off until I have at least double digit satellites locked in. I had 13 yesterday before I took off and it flew great for around 8 minutes or so, but something that did happen that I just now recalled was, I wanted to check out the RTH on it and see how close it would come to the landing pad.
I had it about 25 or so meters off the ground when I hit the RTH button and it did exactly what it is suppose to do...........at first.
It went higher and then started to descend and was coming down pretty close to the pad until it got about 5 or 6 feet off the ground and then I guess it did the Prop Wash effect that has been talked about on here and just dropped the rest of the 5 or 6 feet and bounced off the ground and back up. It didn't seem to hurt anything and I kept flying for a couple more minutes and did another landing and right after that came the fly a way.
The first time I lost control of it about 2 weeks ago, I didn't do any RTH or touch n go landing. I was just flying and all of a sudden it just took off to the left and started to climb and I could not regain control so again I hit the lock button. I live in a fairly remote area in Southwest Virginia and not a lot of wifi around me so I just don't know what could cause it unless it is some kind of defect. I took the top of the 5w off and looked really good to see if anything could be loose or any soldering issues, but nothing.
I have flown it twice today without any issues, but it does worry me everytime I fly now, worried it may just take off on it's own again.
Anybody else experience anything like this with this drone ?
Jul 22, 2019, 11:26 AM
Could be this Quad is made by the run of the mill “toy” company in China. They have a very impressive “quad dedicated” looking web page, social media front but they also make “Rollie Pollies, Pokémon, Plastic babies that pee” etc.
But DON’T get me wrong I have had some decent low end budget quads from China too. My Xplorer Xero has been nothing short of awesome for me, despite as near as I can tell they folded and others have had horrific fly away stories. 3DR, comes to mind too although they were mid ranged and trying to go commercial operation.
More than likely your issue may be with location and it is low end tech. Unless you’re flying higher end or lines like Spektrum, Futaba, DJI the frequency these models operate the flight on is UNLOCKED 5ghz & that’s shared by zillions of other things Your issue could simply be a brown out issue aka loss of comms, sounds like that.. I’ve been to a few flying parks that have literally “known brown spots”, you’ll lose communication regardless of how expensive or highly rated the Tx/Rx is while flying over or thru the hot spot. I’ve seen some pilots with very expensive jets/planes just dump cause they couldn’t get outta an area they knew was bad. The two that come to mind are in Ca in So Cal, aka crowded vs Gulfport. The local utility companies have monitors on eqt all over town to send operational info, open-close valves etc from their headquarters. Fly over one of their modems, plop...you drop from the sky.
My best advice, sorry maybe others have better....which is likely as I’m not the smartest, is simply fly knowing you are likely especially in areas around other 5ghz to have interruptions. The 2.4 ghz is crowded with old cordless phones, garage door openers, baby monitors etc. Now 5 is getting MUCH MORE crowded with modems, doorbells, cameras aka home monitoring etc. Name brand companies like Spektrum, Futaba, DJI focus on flying and LOCKING in those signals, Chinese companies that bulk out entry level budget quads generally don’t have the same goals, laws, need or desire. Despite a fancy looking web page the thousands of Chinese “Quad” companies like my Xplorer may be using the same tech in my quad to “make baby” pee pee on command or “Optimus Prime” transform when he is near “Bumble Bee” as far as I could tell. Not to mention they wouldn’t disclose that on their web pages for quads.
Many moving parts, but the adage “you get what you pay for” applies to our hobby. I don’t expect my Xiro will be as safe as any DJI, cause it’s a knock off.
Jul 22, 2019, 03:53 PM
BigRHS's Avatar
Appreciate the reply.
I pretty much figured the " get what you pay for " is what is happening with this drone.
I flew helicopters for years until I decided to sell out and get into ground RC and have been doing that for several years now, but I decided I wanted to get back into flying and drones in particular, but I didn't want to start off with a $500 or higher priced drone until I was sure that I wanted to do this fully ( which I have decided I do ) and also learn to fly and control a drone.
But I am going to sell all of my ground RC or trade it and get a much better drone than what I have now.
I'm 60 now but I am always looking for something new to do and a new skill to learn, besides the drone can help me keep an eye on my land.
I guess until I get a better quality drone I will just have to be a little more careful with this one.
Jul 23, 2019, 01:51 AM
jno
jno
I make them for friends who have 5w bugs (or jjpro x5w etc etc).
The next step is to improve the beauty of these adapters.
These are the latest handmade.
The next ones will be done with the 3D printer and they will look like they were made by the factory ..
Jul 23, 2019, 09:57 AM
jno
jno
The work for one battery adaptator is done.
See the difference new vs old adaptator.
( is impossible do better)
Jul 26, 2019, 03:58 PM
Originally Posted by x13x54
I haven't noticed any limits on waypoints, does the app refuse the waypoint when you place it, or only after you hit submit?
About the telemetry, did you notice that it stopped counting on your phone and was stuck on 999m?
If that is the case i'm not sure if we can modify it as 999 is a very illogical number for the phone to stop counting, and if the phone limits it to 3 digits then it should just show 000, 001, 002, etc or 100, 101, 102 (for every ten meters) from there on, if it stops at 999 the drone like does not transmit any value higher than 999.
I've noticed this too, when I place a waypoint too far away and click 'submit' (not sure what distance exactly), it comes up with a message that just says FAIL. When I do waypoints closer to my location, it doesn't seem to have a problem and doesn't come up with this "FAIL" message.
Also noticed that my map is a grey chinese map, and occasionally it will switch to google maps for no reason but that is grey too. Also, satellite view shows grey as well. Basically unflyable in it's current form for anything map-related.
Mini-Review MJX Bugs 6 / RC Fun Flyer's Thread Blue Bugs Mini Multirotor Drones 591 May 22, 2019 08:38 AM
Mini-Review MJX X708 The best initiation drone Review and flight, Clon MJX Bugs 2 LTECNIC Mini Multirotor Drones 0 Nov 04, 2017 06:43 AM
New Product MJX Bugs 3 Brushless RTF 310 GoPro Carrying Quadcopter - $116 lmpuIse Multirotor Drone Talk 2 Dec 13, 2016 08:38 PM
Build Log Dicky Bug/Canadian Bug/Dragonfly build thread ORANATOR Parkflyers 23 Nov 28, 2008 10:58 AM
