Jan 16, 2018, 06:17 AM
Help!
Taranis X9D+ (EU) and FrSky R-XSR binding issues
So far I've been having a hell of a time trying to get the R-XSR to work with the Taranis X9D+ and the Matek F405-AIO.
I've even tried using the uninverted port to no effect.
Here is the wiring I'm using for the F405-AIO to the X-XSR receiver.
https://flic.kr/p/DS7Udg
Short video:
Frsky Binding / Connection issues with Taranis X9D+ (EU) (2 min 20 sec)
Note: Receiver firmware has been updated with latest Frsky firmware. Taranis (EU) is using firmware opentx-x9d+ 2.2.1 Date 2017-12-17 EEPR 218
Thing is I have two of these receivers and its the same issue with both. I'm guessing that the odds of having two bad receivers is pretty low and that I'm seeing a firmware conflict of some sorts.
Anyone have success with this receiver ?
Thanks in advance!
Resin
Jan 16, 2018, 08:10 AM
FA3PR9WM79
Oldgazer's Avatar
I'm not conversant with regards to the EU firmware, but I have read about some issues.
As a first suggestion, did you re-bind the receiver to the radio after you flashed the new firmware?
Secondly, which mode do you have the receiver in? D8, D16???
Third, post your question in the Radios forum....
Jan 16, 2018, 05:41 PM
Currently using D8 as I dont need / use a full set of channels.
Beyond that the issue is resolved. Swapped out the receiver card for another R-XSR, flashed it and assigned it to UART-2. After that was test flying it within the hour.
Here is the completed build...
https://flic.kr/p/23tEBo9
https://flic.kr/p/23tEBjb
https://flic.kr/p/23tEBxs
https://flic.kr/p/23tEBKG
Jan 16, 2018, 08:26 PM
You likely have a firmware mismatch. If you have TX EU firmware, you need EU firmware on RX for them to bind.
Jan 18, 2018, 01:51 AM
Possible but hard to confirm as the receiver card i removed had it's bind button come off. (Not a great week for me)
I did however update the Taranis firmware and that of it's internal module. Overall though the documentation for the R-XSR is very limited and says squat about the EU requirements. I can imagine that this is causing a huge number of issues for EU users.
Jan 18, 2018, 02:38 AM
Mismatch firmware applies to all Frsky RX and TX. It is a source of problem for a lot of people who can't bind. People don't realize that the internal module has it own firmware aside from the TX firmware.
Help! Binding a Taranis Plus with a frsky XSR receiver. Sil FrSky 41 Feb 10, 2018 10:11 AM
Discussion Difference between FrSky Taranis x9d eu and us version BenAllen Multirotor Drone Talk 2 Jul 13, 2017 02:41 AM
Discussion Frsky binding issue.. naze32 rev5 and XSR receiver WoooSaaaW Beginner Multirotor Drones 5 Jun 04, 2016 08:13 PM
Discussion Speedix ARF S250Q w/CC3D or KK2 compatible with FrSky Taranis X9D Plus 2.4GHz ACCST R retnevel Radios 2 Nov 04, 2015 02:24 PM
Help! Frsky Taranis X9D and X8R Cannot Bind boba7523 Multirotor Drone Talk 3 Aug 13, 2014 02:27 PM
