Jan 17, 2018, 02:42 AM
i was gonna add wood strips inside the stabs through the hinge,but i figured for now the outside will do.ive watched vid reviews on this plane in kit form and many complaints about too much stab flex and tearing.
this ones alot lighter and straighter.
and im still lighter than the old wing,unless i add half roll of packing tape.....slightly over.but i wont be using all that tape.
595DDD83-644A-4C89-9068-B5686D445C71 by Nick Pellegrin, on Flickr
B15935C5-644F-4704-A546-1E1CDB2CC6DD by Nick Pellegrin, on Flickr
8F7348D9-7FD8-4C20-9C29-5BE074290849 by Nick Pellegrin, on Flickr
Jan 17, 2018, 03:04 PM
ive doubled the foam on belly for landing gear and added wood backing,installed the landing gear,i got bigger wheels to put on.
i think ill be right at the .9 lbs flying weight without battery.
im .97 lbs with the old heavy motor mount,so im going to build new lite to compensate for the landing gear support.
wheels and gear came from a 35" span parkzone cub
877B9E11-3EA6-4F61-8148-489AE284CF55 by Nick Pellegrin, on Flickr
A5DF92EE-2296-4465-9BAF-2CA10A7591D1 by Nick Pellegrin, on Flickr
8C10658B-C52A-4611-BC89-19340C52F463 by Nick Pellegrin, on Flickr
Jan 17, 2018, 03:54 PM
Kimbers Keeper.
BHOFM's Avatar
I have been following your thread with some interest. Some very nice work, but one suggestion,
get a sharper blade!
I am working on a FT Alpha now, but my next build may be a 150%, 57" span version of the
Simple Cub. With 8" wheels?
Jan 17, 2018, 04:25 PM
i was just telling myself that,im using hobbico #11 blades,my hard desk i use for a cutting surface keeps eating the tips.....lol.
sharp blade makes way better cuts,but i figured this will be a basher for all my friends to learn on.
this also getting my feet wet in a first time build.....and ive learned a few lessons already.
i cant wait to see your build,if your using the same plane just scaled up,make a note about the missing lines and non symetrical fuse shape,my first one came out with 1 fuse half 1/8 taller than the other by following the printed plans.
maye its the way my printer printem....im not sure.
Jan 17, 2018, 04:49 PM
Kimbers Keeper.
BHOFM's Avatar
How did you print your plans, tiled, full size? I have had that problem with tiled plans, but never
with full size. I print from the PDF at what size I want directly to the printer. I have a Brothers
Laser Monochrome for plans, $75 cartridge will print about 5000 pages. Couple years for me.
I use a cutting mat and #11 surgical blades. They don't last as long as the #11 hobby blade, but
they are sharp. I use hobby blades for non critical things. I have 12", 18", 36" and 72" straight
edges handy at all times, #2 pencils and a electric sharpener next to the work table.
https://www.ebay.com/itm/SCALPEL-KNI....c100005.m1851
Main thing is to be comfortable while you are working! Main thing!
Jan 17, 2018, 05:55 PM
you definatly have a nice setup.
i printed in tiles,the A plans,my first thought was to download the file and bring it to office max to print full size for me.
Jan 17, 2018, 06:21 PM
Kimbers Keeper.
BHOFM's Avatar
The printer should print the full size in tiles on it's own, tell it, Poster, 100%, With grid lines,
When you are old, single and unlimited resources, you can enjoy life.
Also, RC is not my primary hobby! I have a much more expensive one!
Jan 17, 2018, 06:33 PM
thanx for the tip,i tried the judi seajet in poster mode 100% and i it printed fine.
ill have to try the cub again,but it still bothered me that the fuse wasnt a mirror image.
we all have other hobbies,im into astronomy,airgun target shooting and kayaking.
always another exciting hobby to pull us away from other hobbies.
nice cycles by the way.
Jan 17, 2018, 06:43 PM
ive made my target weight rtf without battery .9 lbs.
still have cleanup of seems,maybe some added packing tape on bottom of fuse.
i wasnt sure i was gonna be under 1lb with the added landing gear and support ive added,but it all worked out well.i still need to to order the proper size weight battery.the 2700 i have is .4 lbs,ideal battery is .2-3lbs .....im thinking a 3s 1300-1500 mah will be plenty.
sofar the new cub is 3/4lb lighter by switching to $1 foam board over the walmart board.
i still have to go get the bigger wheels i have stored at another location.
but overall im very happy.
gonna build the ft old fogey next....cant wait.
9CDA55C2-3C6D-46C6-9FE8-D6F4DF1E170F by Nick Pellegrin, on Flickr
A6C7D59E-FA92-4C92-8E62-2280BCD06136 by Nick Pellegrin, on Flickr
2C67CDEE-15F8-4581-A575-C00692FF9403 by Nick Pellegrin, on Flickr
Jan 17, 2018, 07:05 PM
Kimbers Keeper.
BHOFM's Avatar
Don't get obsessed with the weight thing. I make copies of profile 3d planes using DTF and they
are always heavier than the original. They do how ever fly better in wind than the originals did.
Weight can be a friend. Not gross amounts, 10 to 15% is fine.
Jan 17, 2018, 07:21 PM
i just weight total weight with my woreout hk 3s 1300 mah (88 grams) and im right at 1.2 lbs ready to fly,just the completed plane .97 lbs.
im happy with that.
if i throw in my big 2700 mah battery im too heavy at 1.6 lbs,the first cub i wasnt worried about weight.....but now i am....lol.
so i ordered a budget 3s 1300 mah for $13,be here next friday .
my curret 1300 mah cant handle the load,rpm drops fast.
i been using it strictly for my fpv moniter and equipment for the past ferw years so it never really had a discharge command.
Jan 18, 2018, 12:54 AM
printed some dummy valve covers......because i can.
5A9D275C-C2DC-40B5-8F4F-CBAF7B35000A by Nick Pellegrin, on Flickr
Jan 18, 2018, 01:11 AM
Kimbers Keeper.
BHOFM's Avatar
Scrap of foam and a black marker! Low tech.
Jan 18, 2018, 01:16 AM
i was about to do the same.....then i thought.....lets see what thingiverse got for cubs.
i woulda been happy with marker too.
ill probably marker the windows.
im debating on adding paint to this cub.
Jan 18, 2018, 01:22 AM
Kimbers Keeper.
BHOFM's Avatar
The motor parts are more than just marker! Doesn't show good in the first shot.
Cool Flite Test FT Simple Cub molenjin Serbia 5 Jul 06, 2017 05:31 PM
