FlyingCinema CineTank MK2-L with CineGimbal - RC Groups
This thread is privately moderated by rollys, who may elect to delete unwanted replies.
Jan 13, 2018, 12:26 PM
Trader Rating: 0
Flip on Tech
rollys's Avatar
$850.00 USD
Buyer pays shipping
For Sale
$850.00 or Best Offer
Fully assembled.
Bind and Almost-Ready-to-Fly
GoPro camera not included.
Buyer pays shipping. I'll provide you the shipping vendor contact info that will professionally pack it. You can specify how you want it shipped and pay them directly.
Clean section has been modified with 50mm standoffs so it can accommodate 45mm wide x 50mm height "in the trunk". It'll handle a host of different 4S LiPo batteries. This has been setup and flown with Multistar 4S 6600 mAh LiPo pack.
Depending on your type of flying, can go as low as 11" props
You'll need a minimum 5-channel Transmitter for the Tarot ZYX-M Flight Controller to have flight modes:
- GPS / Position Hold
- ATTI (Attitude holds Altitude but not Position)
- Return to Home
6-channel Transmitter
- Control the Tilt Angle of the gimbal
7-channel Transmitter - additional Flight Modes:
- IOC (Intelligent Orientation Course / Headless Mode)
- Course Lock
8-channel Transmitter
- OSD has built-in dual camera switch controllable from transmitter. You can add an FPV Camera to the OSD and switch between this and the GoPro camera.
Build specs:
  • Tarot ZYX-M with GPS
  • Tarot ZYX OSD
  • Spektrum AR8000 with Satellite Receiver
  • EMax MT3510 600kV
  • HobbyWing 40A ESC
  • Andoer 13 x 5.5 T-Series Carbon Fiber Props
  • Tarot Suspension Motor Mounts
  • CineGimbal 2 Axis for GoPro Hero 3 (not included)
  • T Motor GB2208 Gimbal Motors
  • AlexMos 3-axis 8-bit Controller
  • TS832 Video Tx
  • StrobON Nav Lights
  • RMRC LED Blue and Red Lights
  • Approximate AUW: 2406g / 84.9oz with Multistar 4S 6600 mAh LiPo battery
OEM Description:
CineTank MK2 features include:
•New open bottom dirty plate (gives you faster and easier access to your electronics)
•New X brace top dirty plate
•New placement for silicon dampers, 3 on each corner, 2 additional on front and back
•Total of 16 silicon dampers to allow tuning for different conditions and weights
•Additional space between silicon dampers
•Optional hole patterns for Flight controls and PDB
•New side plate design with Flying Cinema logo
•Optional Flight control/ PDB screw holes on dirty section.
•New side plates with FlyingCinema logo
•Removable bottom access hatch with provisions for 500 size heli landing gear
•New plastic mount molded parts
•New clean section, extended 10 mm forward to better support 12 inch props and gimbal
•6 new slots for velcro straps, 2 horizontal and 4 vertical
•Additional side plate indents for screw clearance
•Optional standoff placements for additional reinforcement
•Overall weight of complete frame reduced by 24gr
•New gimbal adapter slots
•New dipole UHF antenna place holder
•New SMA antenna socket
Original Features:
•514 mm diagonal Motor-to-motor.
•8 and 12" props max.
•Jello Free.
•No props in view even with GoPro Wide settings.
•Carbon Fiber Arms that provide better aerodynamics and vibration dampening.
•G10 frame with honeycomb design to add strength and drastically reduce weight, also RF transparent for better range.
•All hardware is hex M3 stainless steel, only one tool needed to assemble the frame.
•Flight controller mounting holes to support cc3d, Revo, Naze32, KK2, ArduPilot, etc.
•The dirty section (bottom) has walls to increase strength and torsional rigidity of the copter and also protects your ESCs and other
electronics.
•Camera plate adjust fore and aft to change CoG and help you balance your craft.
•Wires from motors can be routed via the carbon fiber tubes to protect them in the event of a crash.
•Low profile landing gear pads.
•The quad frame is manufactured in-house in the USA!
Disclosure:
- This item does not come with any expressed or implied warranty.
- Buyer assumes all responsibility and liability in the use of this item.
- Radio control transmitter not included. Buyer needs to supply Spektrum or compatible transmitter
- Battery not included.
- AS IS WHERE IS - NO Return or Refund.
Sold Cinetank MK2-L with Gimbal and lipo shredzoo7 Aircraft - Electric - Multirotor (FS/W) 1 Aug 25, 2016 10:00 PM
For Sale Cinetank MK2-L All parts are NIB shredzoo7 Aircraft - Electric - Multirotor (FS/W) 1 Feb 12, 2016 10:55 AM
For Sale CineTank Mk2-L 514mm RTF, 1.3Ghz FPV, Taranis Controller, EzUHF 433mhz erick3150 Aircraft - Electric - Multirotor (FS/W) 0 Jan 20, 2016 07:21 PM
For Sale CineTank Mk2-L 514mm RTF, 1.3Ghz FPV, Taranis Controller, EzUHF 433mhz erick3150 Aircraft - Electric - Multirotor (FS/W) 2 Dec 07, 2015 06:53 PM
For Sale MK2 - L CineTank FlyingCinema Kit, with Esc's, Motors, Props and small Camera pod javg37 Aircraft - Electric - Multirotor (FS/W) 0 Jun 21, 2015 03:59 PM
