Eagle Tree Vector + OSD , PSU and GPS V1 + LED Alerter - RC Groups
This thread is privately moderated by rollys, who may elect to delete unwanted replies.
Jan 13, 2018, 10:48 AM
Trader Rating: 1
Flip on Tech
rollys's Avatar
$175.00 USD
Buyer pays shipping
Sold
$175.00 or Best Offer
OEM Description*
The Vector has everything we hobbyists have dreamed about for our recreational FPV models, in one small, lightweight easy to use product:
  • SIMPLE to set up and operate "out of the box" for both fixed wing and multirotor, with no PC required
  • Built-in OSD with COLOR GRAPHICS!
  • OSD display is fully configurable, so you can make the screen as simple or robust as you want it!
  • OSD still operates even if your camera fails!
  • FIXED WING and MULTIROTOR Flight Controller with GPS modes and RTH
  • Fixed wing: Traditional fixed wing, Elevon, and V-tail planes
  • Multirotor: Tricopter, Quadcopter, and Hexacopter
  • Built in FLIGHT DATA RECORDER helps take the guesswork out if something goes wrong
  • COMPATIBLE: PCM, SPPM and S.BUS receiver support, with 4 types of RSSI
  • EXPANDABLE with additional sensors, accessories, and internet firmware updates
  • FLEXIBLE: fly with or without your FPV equipment
  • REDUCED WIRING: innovative wire harness with power distribution simplifies hookup
  • Current sensor with quiet and efficient filtered 12V* and 5V Power Supply Unit supports up to 6S packs
  • Built-in altimeter, IMU and magnetic compass sensors
The Alerter is small and lightweight, the powerful Alerter Buzzer/LED provides important audiovisual information about your Vector or MicroVector equipped model's status, and a "smart" lost model/battery saver alarm. Great for use when flying either FPV or LOS!
  • LOUD multitone buzzer with programmable volume
  • Three SUPER BRIGHT LEDs with programmable brightness, and diffused viewport
  • Unique, programmable Inactivity Alarm serves as a lost model alarm, and alerts you if you forget to disconnect your flight pack
  • Buzzer provides audible indication of errors and other events
  • LEDs show Vector status, number of GPS satellites in view, and more
  • For multirotors, LED brightness and buzzer volume can be programmed to be at highest levels only when armed
  • Comes with 6"/15cm connection cable
IMPORTANT: the Alerter's high powered LEDs and Buzzer require that the maximum 5V PSU draw be reduced from 1A to 500mA. Also, the Alerter is not compatible with the power function of the GoPro AV Cable. See Vector manual for more information.
*Disclaimer: Above description is from manufacturer's description. Seller not responsible for any error or omission. This item does not come with any expressed or implied warranty. AS IS WHERE IS. Buyer assumes all responsibility and liability in the use of this item. Buyer pays shipping.
Jan 13, 2018, 05:13 PM
Trader Rating: 2
simplechaos's Avatar
PM sent
Sold Eagle Tree Vector #2 w/ v2 gps, alerter Mattsrcking FPV Equipment (FS/W) 2 May 22, 2017 05:19 AM
Sold Eagle Tree Vector (FC&OSD) XT60 PSU and GPS atpcop FPV Equipment (FS/W) 2 Feb 17, 2017 09:44 AM
Sold Eagle Tree Vector Alerter V2 GPS Eagle Eye GS InfoPanel D Dale Aircraft - Electric - Multirotor (FS/W) 2 Feb 06, 2017 04:26 PM
Sold Eagle Tree Vector with led alerter DERBYJ Aircraft - Electric - Multirotor (FS/W) 0 Oct 22, 2016 10:37 AM
Sold Eagle Tree Vector w/GPS + Alerter + Info Display panel scarrz FPV Equipment (FS/W) 1 Mar 05, 2016 06:34 PM
