This thread is privately moderated by bill_delong, who may elect to delete unwanted replies.
Jan 13, 2018, 09:53 AM
Did I make the A Main?
bill_delong's Avatar
Which bearings are right for me?
If your car comes with cheap plastic bushings, some have asked if it's worth it to upgrade to bearings, and if so, which ones?
For casual bashing where performance isn't important then upgrading to shielded bearings isn't really important, but if you would like slightly faster acceleration, smoother/quiet operation and increased efficiency with slightly longer run times, the consider upgrading to bearings.
There are tons of cheap bearings available on eBay and they will do fine, I agree that rubber sealed bearings are nice and also a huge fan of AVID bearings. They have tons of kits available for most cars on the market, if you don't see your car listed, simply send them an email and chances are they will make a kit available very shortly:
https://www.avidrc.com/product/1/bearings/
If you want to take performance to the next level, then consider the Revolution series through AVID, they have a non removable metal shield on one side and rubber seal on the opposite side. Metal shields offer less drag/weight which improve performance but are more difficult to clean. If you don't plan to clean your bearings then I would just buy double metal shielded bearings and toss them out when they get crunchy for the best performance. If longevity is more important, then go with Revolution bearings for a good balance. You can also leave the rubber shield permanently removed leaving one side exposed to help reduce drag, simply place the exposed side of the bearing toward the inside of the hub carriers. To further increase performance you can flush the grease with brake cleaner and use a dry teflon lube. Only problem with dry teflon is that you will need to clean and lube your bearings more frequently (like every 10-15 battery packs) or you will risk damaging your bearings... normally I inspect and clean my rubber sealed bearings every 25 packs anyway to get the longest life. To further increase performance then consider ceramic bearing which reduce weight, but this option is cost prohibitive for bashers, ceramics are more popular for stock racing. For my open mod cars I like to use Lucas Assembly Lube to repack my bearings because mod motors are way more powerful and easily overcome any drag characteristics with double rubber shielded bearings packed with traditional bearing grease. Removing the rubber seals is very easy:
RC How-To: Clean rubber-sealed bearings, completely! (6 min 46 sec)
With regular care and maintenance, a set of bearings can last indefinitely.
Check out more stuff on My Bookmarks page!
Discussion Hillary Clinton Won't Say If The Right To Bear Arms Is A Constitutional Right kenpoprofessor Life, The Universe, and Politics 3 Jun 06, 2016 06:09 AM
Discussion Which Trex is right for me? killdasoundboy Electric Heli Talk 4 Dec 28, 2006 06:39 PM
Discussion Mountain Models dilema: which one is right for me? Taylor Mullin Parkflyers 10 Nov 03, 2006 03:05 PM
Which Logo is right for me??? roni Electric Heli Talk 16 May 02, 2005 03:48 PM
Which plane is right for me? Cubits Beginner Training Area (Aircraft-Electric) 8 Dec 28, 2002 10:46 AM
