Feb 10, 2020, 01:43 PM
Grumpa Tom
Kmot's Avatar
Wow. It is super impressive!
Feb 16, 2020, 10:42 AM
3D printed OS .25FSR engine
Does anyone print any real model airplane engines ? I have used a McCoy .19 engine that I ran a shaft thru and bolted an inrunner to the back of the case . It worked quite well but was rather nose heavy . A nice lightweight dummy engine would work much better . The crankcase could be hollowed out for mounting a brushless motor or mount bearings to support a shaft running to a prop adapter on the front end . I just finished a scratchbuilt Sterling/RCM Royal Coachman and it would be awesome to have a dummy engine on the nose !
Any help would be appreciated . I scanned the web for any files that might work but no luck . BTW, you guys are real artists . Those scale multi-cylinder engines are awesome .
Thank you .
Feb 16, 2020, 02:12 PM
rip
ripacheco's Avatar
Originally Posted by mike912e
Does anyone print any real model airplane engines ? I have used a McCoy .19 engine that I ran a shaft thru and bolted an inrunner to the back of the case . It worked quite well but was rather nose heavy[...]
Yes. Itís been done. Someone must have an STL file around...
Hobby King/Durafly Das Ugly Stik.
Discussion 3D Fpv Flying my ZMR 180 - Have you tried 3D Fpv? surferguy Multirotor Drone Talk 0 Aug 06, 2016 10:53 PM
Build Log My first 3D from build to Maiden. FT-3D Pilot_MM 3D Foamies 7 May 02, 2016 08:50 PM
Discussion Need help choosing 3D plane for my engine PlaneCraz3d 3D / Fun Fly Fuel Planes 9 May 21, 2012 07:15 PM
Discussion Simple Mini 3D - My first "engineered" design (with plans) mikebergy Foamies (Scratchbuilt) 16 Feb 23, 2010 09:23 PM
Discussion Which engine and prop for my model tech magic 3d boos boy 3D Flying 2 Oct 05, 2008 02:07 AM
