6 servo wing - RC Groups
Jan 10, 2018, 03:25 AM
6 servo wing
Hi, using a A9 on a PCM Elvira, itís a 6 Servo wing. My issue is that all control surfaces work ok unless using crow. All functions normally ie flaps go down ailerons go up. Set on throttle stick. The outer ailerons donít recognise crow and work normally. Crow screen doesnít allow for a second set of ailerons and have tried p mixes, aileron to outer ailerons etc. Cheers
Jan 10, 2018, 02:00 PM
Xpress..'s Avatar
Have you tried to assign all of the aileron servos to just AILE in the transmitter?
Latest blog entry: Multiplex 10% off sale!!!
Jan 10, 2018, 04:05 PM
Yes, tried that, I could make ailerons assignment the outer ailerons then I would have flaps and outer working but no inners. If I could use a p mix for throttle to outer ailerons that would work
Jan 10, 2018, 07:16 PM
Xpress..'s Avatar
So, for demonstrational purposes, this is how you have ailerons assigned?
CH1: AILE
CH2: AILE
CH3: FLAP
CH4: FLAP
CH5: AILE
CH6: AILE
Correct?
Jan 11, 2018, 05:05 AM
Got it sorted, had outer ailerons and ailerons asigned to j1 but named them gyro 1 and 2. I did this so I could tell what control surface I was adjusting in travel limits and end point adjustments etc without looking at channel assignments. My channel assignments are not in logical order as my receiver wiring was already connected and I assigned each control surface to where they ended up. Short of is renaming the outer ailerons AILE allows crow to recognise it. Hope that makes sense. Thanks for your help
Jan 26, 2018, 09:00 AM
Woodstock 1's Avatar
Hi, I'm trying to do this as well, and I'm not very good at programming. Does your method allow you to use the middle surface as ailerons, and then as flaps for landing?
Chris
New Product Inside F5J -- Excellent F5J/ALES 6-servo wing kit ripacheco Electric Competition Soaring-F5J/ALES/e-Soaring 2208 Yesterday 10:04 PM
Discussion 6 servo wing MZ18/MZ24 RaceMag Graupner Ė OPENHOBBY 6 Dec 08, 2017 03:48 AM
Question 6 servo wing with x9503? Siddasdad Electric Competition Soaring-F5J/ALES/e-Soaring 1 Jun 20, 2017 03:24 PM
Discussion JR XG11MV with 6 Servo Wing shrsailplanes Sailplane Talk 6 Oct 13, 2016 03:08 PM
Question 6 Servo Sailplane Wing JimHSoars Sailplane Talk 19 Nov 04, 2015 04:10 PM
