Eagle Eyes: Can it default to 'diversity'? - RC Groups
Jan 09, 2018, 10:18 PM
Fly FPV, sleep; repeat
twinturbostang's Avatar
Everytime I power on my Eagle Eyes, it defaults to 'Input #1'. But I want it to default to 'Diversity', because I sometimes forget to manually switch it to diversity before I fly. When I forget to do this, it only reads Input #1 through the entire flight.
The only menu options for diversity seem to be "sensitivity" and "beep". Seems pretty silly to not power up in Diversity mode. Can this be changed?
Brian
Jan 10, 2018, 06:06 AM
You can set the Eagle Eyes default input behavior here.
Jan 11, 2018, 10:47 AM
Oh ok. Do I have to have Vector attached always for this to work? I only have one Vector equipped aircraft.
Jan 11, 2018, 08:34 PM
No you don't need Vector attached always. Connect your EE to the computer and make the setting change. And it will remember the setting in stand alone mode.
If you use EE with a Vector again the setting in Vector will override the EE setting.
Better to make the setting in your Vector to Diversity and the EE will be fine for all cases.
Geoff
Jan 11, 2018, 10:14 PM
Cool. Thanks!
Jan 13, 2018, 05:56 PM
I did a firmware update to the Eagle Eyes. It seems to remember the settings from last time it was powered on now. So that's good. I can set it to 'diversity', and next time I power on, it starts up in that mode.
The Vector software does not seem to be able to control the Eagle Eyes directly though. It did recognize it needed a firmware update. But other than that, I can't set the EE parameters through the Vector software. It keeps coming up in "offline" mode. Unless I have my Vector connected also. So it seems the only function of the USB port on the Eagle Eyes is to do firmware updates.
Jan 14, 2018, 06:29 AM
I recall that in the older Data Logger software there was a menu option to connect the EE directly to the PC but that does not display for me anymore. May be due to the firmware in my EE is too new for the old Data Logger software.
However its been a while since I changed the settings on my EE so it may be that the settings are only made through the Video link and Vector.
You can also make changes by doing a button press sequence on the EE but that seems very tedious to me.
Geoff
Help! How can I connect a rev c power panel to the eagle eye? arturojgt Eagle Tree Systems 2 Mar 14, 2017 08:20 AM
Discussion Wired Usb Eagle Eyes, Can it be Wireless ?? quadcopter007fpv FPV Equipment 10 Oct 20, 2015 11:27 PM
Help! Eagle Eyes Connection issue, Can't update, no In1, no LEDs emthree_kia Eagle Tree Systems 4 Dec 10, 2013 08:46 AM
Question What can be causing this (Eagle Eyes black&white video problem) hefest FPV Talk 9 Jul 08, 2012 08:12 AM
Help! Eagle Eyes FPV Station - changing default mode? BKMorpheus FPV Talk 3 Apr 18, 2012 12:24 AM
