Question about adding camera to quad. - RC Groups
Jan 08, 2018, 12:47 PM
Hello:
I would like to add a camera to my quad. The quad plus flight battery weighs 380g.
I have a camera that weighs 80g that if possible I'd like to attach to quad.
The motors are 2600kv . The flight battery is 3s.
Your thoughts please.
Rick
Jan 08, 2018, 01:12 PM
It will lift a 80g camera.
Are those 4 inch props ? If so, you should use 5 inch props (or even 6 inch props if they will fit on the frame) to provide more thrust to lift the camera easier.
The 4 inch props will struggle more to lift the camera.
Jan 08, 2018, 01:13 PM
There are so many factors that can influence the carrying ability.. before risking your camera:
..just hang something cheap of equivalent weight, like a rock, under your quad & see how well far and long she flies
Jan 08, 2018, 01:23 PM
Thank you both for your input . Both for the upsize prop suggestion and the rock -in-lieu of camera to start.
Appreciated.
Rick
Jan 08, 2018, 01:59 PM
HUGE! In Japan...
A ZMR-250, very cool! With those motors (RS BR2205 2300kv) and 5048x3 props, my girl's ZMR handles a 1500mah 4S, full FPV setup, 4 LED strips, ImpulseRC LED square, and a Mobius. Mine has Rebel 2206 2360kv, and runs 5051x3 props You'll be just fine!
Jan 08, 2018, 03:08 PM
Thanks, nice quads there!
Jan 09, 2018, 12:38 PM
Fear only fear in life
It will carry a small action cam easily.
Jan 09, 2018, 07:45 PM
HUGE! In Japan...
Hell I forgot, it'll happily carry 2 HD cameras if you're feeling froggy! I used lower pitch props for the 2-camera flights (5048 vs 5051) just in case, but she flew just fine.
FinGolfer's PIDs tuned with Kung-Fu - Goes Ghost-Chasing - A Quad Squad Short (3 min 48 sec)
Jan 10, 2018, 03:22 PM
Thank you all for your help with my question
Regards
Rick
Jan 24, 2018, 06:08 AM
You can easy add an HD camera (I use Apeman HD action cam) to the ZMR 250.
Heres a vid of mine under load with the Apeman.
Mine is also running on 3s lipo.
ZMR250 wetlands ride (5 min 40 sec)
Jan 24, 2018, 11:33 AM
https://youtu.be/uBNybAOz0m8
Thank you for your reply. I enjoyed watching your video.
Jan 24, 2018, 05:08 PM
No probs. Glad you liked it.
Maybe subscribe to my channel if you feel it deserves it.
Jan 24, 2018, 05:44 PM
Just subscribed to your channel. Thanks for the suggestion.
Apr 16, 2018, 04:42 PM
Getting back after upsizing props from 4" to 5" .
My flight time has increased with 5" props
With specifications attached for the 2600kv motors and 20a ESC's on my quad I have questions please.
Looking to try 6" props as they will fit wondering if they will add more stability using camera.
Any issues with 6" props on this 2600kv motors and 20a eESC's.
Should I look at 2300kv motors with ESC at 30a?
I appreciate your help and explanations.
Thank you
Rick
Apr 16, 2018, 07:45 PM
I’d stick with middle of the road 5”. The high KV doesn’t like the bigger/heavier props. If you want more power, look at 4s. I’d suspect that with a decent 4s battery and decent 5” props, you’ll be able to carry as many cameras as you can fit on the quad. It may not be the most nimble option, but there will be plenty of power. Even if they max out at 1000gm (which isn’t racer grade) you’ll have 4kg of thrust wide open. And you are looking at a weight of maybe 500gm with a 4S and the camera. That’s 8:1 thrust:weight. It will be a rocket.
Question Quick question about DIY camera quad build types Tachikoma Beginner Multirotor Drones 5 Oct 27, 2016 08:52 AM
Discussion Questions about building a quad DeezDrones Multirotor Drone Talk 2 Feb 14, 2016 09:22 PM
Question My 450ish quad crash question about frame style Vetalik Scratchbuilt Multirotor Drones 5 Feb 02, 2016 09:50 PM
Help! noob questions about building a quad Trisnpod Beginner Multirotor Drones 8 Oct 12, 2015 08:21 AM
Discussion Questions on adding camera to plane (future pan tilt ability to be added)..TwinstarII markm75 FPV Aircraft 2 May 05, 2007 01:38 AM
