Review of Hubsan H122D X4 STORM - Micro Racing Drone Quadcopter w 5.8G FPV cam - RC Groups
This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jan 05, 2018, 03:44 AM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Hubsan H122D X4 STORM - Micro Racing Drone Quadcopter With 720P Camera - 5.8G FPV and Goggles & DVR flight footage
My new brushed quad from Hubsan, advertised as Micro Racing Drone, just came. Its Hubsan H122D X4 with catchy callsign STORM.
It came in the compact box although my version comes with box style goggles. Never the less, the box was so small that it passed DHL customs process without any expenses. It was delivered to my door in very short time (5 days).
DVR recording on quad
Hubsan H122D X4 STORM 5.8G FPV quad onboard DVR - raw outdoor cloudy sunset flight (5 min 2 sec)
Hubsan H122D X4 STORM 5.8G FPV quad onboard DVR - outdoor maiden flight (3 min 10 sec)
DVR recording on goggles
Hubsan H122D X4 STORM 5.8G FPV quick goggles screen DVR test - maiden flight (7 min 9 sec)
quick LOS maiden test flight
Hubsan H122D X4 STORM - maiden flight (2 min 1 sec)
Description:
  • Material: Carbon Fibre
  • Motor: Coreless
  • Quadcopter Size: 112.5*111*62mm (3.7 inch X 3.7 inch)
  • Weight(Including The Battery): 116.5 g
  • Battery: 7.6V (2S) 710mAh Lipo
  • Camera: Built-in 720P HD Camera
  • Flight Time: Around 6-8minutes
  • Charging Time: 150 minutes
  • Max Flight: 10010 meters
  • Memory card: 4G TF card.
  • Max support: 1- 32GB card class 4 (not included )
  • Transmitter: 2.4GHz Bluetooth TX
  • 4 LED indicators & Rubber feet
  • 4.3inch LCD Screen(Goggles Version)
Function:
  • Flips & Rolls
  • Low Battery Protection
  • Compatible With FatShark
  • Built in DVR (max. 32GB SD card supported) into quad and googles screen
Features:
  • Mini Size - Mini size allows you to fly indoors or within limited space.
  • 2.4GHz TX - 2.4GHz Technology Adopted for Anti-Interference.
  • 5.8G FPV - 5.8G high frequency images transmission gives you every perfect moment of the captured pictures at time.
  • 720P HD Camera - Built-in 720P HD camera are tuned amazingly to capture stunning pictures and videos from the sky.
  • 3D Roll - Aerobatic flight of continuous 360-degree rotation towards various directions
  • Low Battery Protection - When it’s running out of power, the drone will automatically return and fall in take-off point.
In the box:
Standard Version: - If you prefer "ski mask" type googles you can go to this version and, if you already don't own some googles, bundle these entry lever 100$ googles from Eachine which are very good in value/price ratio - Eachine EV100 and my review of them
1 x Hubsan H122D Racing Drone
1 x Transmitter
1 x 7.6V 710mAh Battery
1 x Charger
4 x Blades
1 x Manual
Goggles Version (my version):
1 x Transmitter
1 x HV002 Goggles
1 x HS001 LCD Monitor
1 x Charger
4 x Blades
1 x Manual
Pros:
  • flight characteristics are very good
  • self-leveling flight mode works perfectly
  • compact and great looking design
  • FPV camera is protected
  • antenna is on moving pivot so it shouldn't be damaged in crashes
  • RTF kit – everything you need to start flying LOS (Line of Sight) or FPV (First Person View) style is in the box and ready to fly as soon as you charge the LiPo
  • 5.8G video transmission
  • built in DVR into googles screen so you can record your flight to SD card
  • built in DVR into quad so you can record your flight to SD card
  • carbon fiber frame resilient to crashes
  • props are held in place by screw so no fly-off of props
  • buzzer
Cons:
  • LCD screen is not non-blue screen (check video in post #5)
  • USB lipo charger is poor at balancing individual cells (check details in post #11)
  • FPV cam has no WDR (check post #10)
  • uneven sharpness of the lens - edge is more blurry than middle (check post #12)
Grab yours Hubsan H122D HERE
Jan 05, 2018, 03:45 AM
FPV addict
mlilasic's Avatar
Transmitter details pics
Transmitter feels nice in hand and size is OK.
Jan 05, 2018, 11:34 AM
Image latency
So I'm thinking about picking up one of these in the next few days and was wondering if you could comment on the latency between the H122D and the googles. I've heard that there is a drastic lag, what are your thoughts?
Jan 05, 2018, 07:21 PM
FPV addict
mlilasic's Avatar
5.8G FPV lag & latency & delay test - PASS & non-blue screen test - FAIL
Here is the test of Hubsan H122D FPV system (first part of the video is latency test, the second part of video is test against blue screen):
Lag is OK for brushed quad I believe, but there's blue screen which is not so great for FPV system, but as this is small brushed park &indoor flyer its possible to live with it...
Hubsan H122D X4 STORM 5.8G FPV lag & latency & delay test - PASS & non-blue screen test - FAIL (3 min 5 sec)
Jan 06, 2018, 04:37 AM
FPV addict
mlilasic's Avatar
pics taken with lcd screen built in dvr
Jan 06, 2018, 04:48 AM
FPV addict
mlilasic's Avatar
DVR recording
FPV addict
mlilasic's Avatar
maiden test flight
Jan 07, 2018, 03:58 PM
FPV addict
mlilasic's Avatar
H122D built-in DVR records fine 16:9 720p footage, too bad FPV camera doesn't have WDR and struggles with difficult light conditions.
Maybe on a sunny day or indoor, it will be better... stay tuned...
Jan 07, 2018, 03:59 PM
FPV addict
mlilasic's Avatar
H122D quad onboard DVR flight footage:
Jan 07, 2018, 04:13 PM
FPV addict
mlilasic's Avatar
Usb lipo charge
USB lipo charger
I have an issue with USB lipo charger provided in the kit with hubsan h112d.
Its balancing circuits are poorly designed or USB charger is faulty one:
one cell is undercharged (4.1v) and the other one is overcharged (4.3v)
Jan 08, 2018, 03:35 PM
FPV addict
mlilasic's Avatar
Jan 08, 2018, 03:36 PM
FPV addict
mlilasic's Avatar
and link to raw gdrive video file
https://drive.google.com/open?id=1tp...bTrrFwyDyzCUqi
Jan 11, 2018, 03:07 PM
Pedja
Very nice test,
-Did you test the range of transmitters? Therefore, such a station uses the announced model H501M.
-In the case of the battery, the description states that Hi voltage Lipo (as in DJI and Co.), 7.6v, then normally charged each cell should have 4.35V, so the battery should be 8.6-8.7v.
Jan 11, 2018, 05:37 PM
FPV addict
mlilasic's Avatar
Originally Posted by peter.k
Very nice test,
-No, I did not test the range.
I just tested the failsafe, and its implemented OK, when the transmitter is turned off, quad automatically disarms and buzzer starts beeping which is perfect behavior.
-Regarding battery, Lipo or LiHV, that doesn't justify that one cell is at 4,1 V and 4,3V, that was my point.
And also, provided charger charges battery to standard lipo level of 2*4,2V which is 8,4V as seen in my pictures.
New Product Hubsan H122D X4 Storm 5.8G FPV Racing Drone TechTronic9000 Mini Multirotor Drones 2 Dec 13, 2017 08:56 AM
New Product Hubsan H122D X4 STORM 5.8G FPV Micro Racing Drone Quadcopter With 720P Camera HV002 G guyst Mini Multirotor Drones 2 Nov 27, 2017 11:20 PM
New Product Hubsan H122D X4 Storm Quadcopter who wear a cloth of racing drone vincentduyi Multirotor Drone Talk 0 Oct 16, 2017 06:11 AM
New Product Hubsan H122D X4 STORM 5.8G FPV Micro Racing Drone Quadcopter With 720P Camera HV002 G guyst Banggood.com 1 Oct 09, 2017 06:55 AM
