This thread is privately moderated by tungsten2k, who may elect to delete unwanted replies.
Jan 03, 2018, 03:16 PM
Trader Rating: 4
Dave Johnson
tungsten2k's Avatar
$45.00 USD
Seller Pays Shipping
Sold
Realacc RX5808 Pro Diversity Split with AchilleΣ 2.0
Realacc RX5808 Pro Diversity Split pre-installed with the latest version of the awesome AchilleΣ 2.0 firmware and white Dominator doors:
Description: Name: box.jpg
Description: Name: doors.jpg
Description:
Description: Name: b-antenna.jpg
Description:
AchilleΣ for RealAcc/Other Modules
This is the beloved firmware for RealAcc and other Ground Stations/Modules.
With zero problems, AchilleΣ now dominates in budget FPV equipment free of charge, bringing your hardware equal with expensive commercial products.
Features
• Up to 583 Channels
• Ultra Search , Starts to search into the predefined band-channels until the desired frequency found .If that happen AchilleΣ auto tunes -3Mhz up to +3Mhz and votes for the channel with the best RSSI.
•Manual, classic manual search ,but with the ability to search Mhz by Mhz over the band. With single click is jumping over predefine freqs and by holding the up or down button fine tuning over each MHZ.
•EVENT mode , Searching down all the 5.8 band and keeps in memory only the running channels, then you can browse them one by one.
• FAST mode , a very handy feature to find very fast a frequensy or a band.
•Favorite channels up to 10. You can Save predefine band channel or even a custom frequency. Start Up channel selection.
•Buzzer Alarm for Low level RSSI 10%,20%,30%.
• RSSI Scan Reads. you can change the average scans for RSSI Reads.
• Statistics with percentage for antennas switching.Statistics run and counts when module enters in screen saver mode, if you hit any button you will reset them at once.
• Find Model , Add a patch Antenna to bottom RX (A) and point to the place that the drone might lost , the Graphic interface + buzzer will guide you
• Band Scanner is scanning with predefined channels (48) not the entire 5.8 band .
• Nice and Easy User Interface.
• Buzzer support.
Joshua Bardwell's review of AchilleΣ 2.0:
Achilles Fatshark Module Firmware | REALACC RUNS WITH THE BIG DOGS NOW (8 min 26 sec)
-=dave
Jan 03, 2018, 06:41 PM
Trader Rating: 17
Pm sent.
Sold Realacc RX5808 Pro with Achillez 2.0!!! xGSEadamx Aircraft - Electric - Multirotor (FS/W) 0 Nov 28, 2017 12:06 AM
Sold Realacc RX5808 Pro with Achillez 2.0 xGSEadamx FPV Equipment (FS/W) 0 Nov 27, 2017 10:47 PM
Mini-HowTo AchilleΣ 2.0 firmare on Realacc RX5808 PRO PLUS Diversity Receiver Frimen FPV Equipment 4 Nov 11, 2017 05:10 AM
Sold Realacc RX5808 Pro Diversity 5.8G 40CH Split Receiver w/ LaForge v1.6 Firmware Professor_X Aircraft - Electric - Multirotor (FS/W) 2 Oct 27, 2016 05:25 PM
Sold Realacc RX5808 Pro Diversity - Split Receiver - (Running LaForge 1.6) - Sale/Trade run FPV Equipment (FS/W) 4 Oct 26, 2016 11:17 AM
