Esprit Tech - Estar Fokker Eindecker
Finally true to scale, faithfully structurally reproduced model. Flies exactly like a real airplane. Selected premium quality balsa and plywood. All the parts interlocked together for easy and fast building. Just assemble and then glue parts together.
The Fokker Eindecker
From Esprit
The Fokker Eindecker fighters were a series of German World War I monoplane single-seat fighter aircraft designed by Dutch engineer Anthony Fokker. Developed in April 1915, the first Eindecker ("Monoplane") was the first purpose-built German fighter aircraft and the first aircraft to be fitted with a synchronization gear, enabling the pilot to fire a machine gun through the arc of the propeller without striking the blades. The Eindecker gave the German Air Service a degree of air superiority from July 1915 until early 1916. This highly prefabricated kit belongs in the "Super Scale Competition" models category. Once built, the airframe is extremely light and clean but still able to withstand the high loads and stresses associated with aerobatic flight. The manufacturer uses the latest construction techniques including Laser CNC cutting to achieve high strength and low weight. Each part and every detail are meticulously made.
eindecker (1 min 19 sec)
Special Features
  • Control surfaces: Ailerons, Elevator and Rudder
  • All balsa/ply built-up construction
  • Fully illustrated instruction manual
  • Laser cut interlocking structure
  • Scale wire landing gear
  • Interlocking parts for easy and fast building
  • Just assemble and then glue it
Photos
More Information:
http://www.espritmodel.com/estar-fok...ecker-kit.aspx
Jan 03, 2018, 06:11 PM
Bill Glover's Avatar
Apart from the fact that it has ailerons, which the full-size didn't!
Latest blog entry: Eachine QX65 FPV quad review
Jan 03, 2018, 11:55 PM
DFS#000178
Rampage's Avatar
Almost $200 for a box of wood is kind of expensive.
You can get the BUSA 90-size 80" Eindecker for just a little bit more money. And the 40-size 60" Eindecker is $110..
Jan 04, 2018, 08:38 AM
Morning Light Mountain
badbill's Avatar
Never mind wrong thread!!
Jan 04, 2018, 10:07 AM
Admin Deluxe
Jim T. Graham's Avatar
No comments have been removed.
Jan 08, 2018, 01:55 PM
Living in the south of France
paulinfrance's Avatar
I have built them both, Fantastic quality, My 80" one has a twin Saito in it and it is the 'bees knees'.
Jan 08, 2018, 03:04 PM
I have all of the BUSA 1/6 fighters, very cool. I wish BUSA would "update" the Eindecker! The 80 inch is woefully out of scale, the .40 a little better. I think there is room for this one, though, I agree, a little on the expensive side. I will probably buy one.
Jan 08, 2018, 06:47 PM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
Tough crowd...
Jan 08, 2018, 06:49 PM
proctor museum scale
http://www.proctor-enterprises.com/p.../eindecker.htm
Jan 09, 2018, 08:01 AM
Originally Posted by cmulder
Wow, amazing that Proctor are still around. I remember when the Antic first came out.
And their Eindecker looks beautiful (with wing warping rather than ailerons ).
Jan 11, 2018, 08:42 PM
Computer says No .....
stewjay's Avatar
Beautiful flying with such an antique design.
I may convert my horrible HK Tuff Trainer 2 to an Eindecker but most likely to a Beliot. Wish me luck, will be a fun project.
Jan 12, 2018, 03:16 AM
Maybe a Bleriot
Jan 12, 2018, 03:23 AM
I don't understand the need to chastise a product so quickly. If you don't like it, just move on. If you can get another model from someone else that's also great but don't dump in a review thread. Its just poor form.
Jan 12, 2018, 04:20 AM
First of all this is a discussion forum ("Electric Plane Talk"), and this is a news item not a review.
If a model is promoted here as being "Finally true to scale", "faithfully structurally reproduced" and a "Super Scale Competition model" then IMHO it's quite valid to point out that actually there's a major problem in that it has ailerons, which are totally non-scale.
It's very likely some people are unaware that the full-size didn't have ailerons, so depending on what they might be considering this model for it could be important for them to know that it's not quite as accurate as stated.
Jan 31, 2018, 10:00 AM
I Fly!
jrtubb's Avatar
Ok so correct me if I'm wrong but this kit is new, designed for electric and laser cut, the BUSE is old, Die Cut and for glow. Having laser cut and already designed for electric makes it worth the price for me for sure. Laser cut also makes it a ton easier for getting new people to consider building too.
Discussion Fokker E.III Eindecker - Laser Cut Balsa Kit 1520mm (60") Secretsenor Electric Warbirds 3 Aug 28, 2019 03:16 AM
Build Log Fokker E III Eindecker, Peter Rake design. WS 60" bth Scale Kit/Scratch Built 32 Mar 09, 2019 05:52 AM
News eStar Fokker D.VIII Kit Jason Cole Scale Kit/Scratch Built 11 Jan 03, 2018 03:57 PM
Discussion 1/6.5 Fokker E.III Eindecker Mfight43 Scale Fuel Planes 5 Jun 16, 2017 07:10 PM
