Pike Perfection F5J BNF - RC Groups
This thread is privately moderated by Jubz, who may elect to delete unwanted replies.
Jan 03, 2018, 01:33 PM
Trader Rating: 26
Subliminal User
Jubz's Avatar
$2,075.00 USD
Shipping negotiable
For Sale
Pike Perfection F5J Light BNF For Sale
* Orange & black Pike in the first pic
- Excellent condition, original owner, flown for half an ALES season, no dorks, hard landings or strikes, some scuffing on the fuse's belly due to landings
- Specs and setup below; flies like it's on rails, solid flier especially when the winds pick up
- Includes Samba fuse and wing/tail bags
- Built by Ali Khani/Flight Comp
- BNF, add battery and fly; can email the model settings for OpenTx 2.2 (Horus X12S)
- $2075 obo, local pickup preferred, Paypal (no fees to me) accepted, S&H in CONUS negotiable
- Can bring it to the JEM DLG Contest in Long Beach, CA on Jan 20-21, 2017 (will also be there Friday 1/19)
- Brief video clips of it flying at ElDo: https://goo.gl/YiU2NC
AUW: 1612 g (57 oz)
CoG: 103 mm *1300 mAh battery (120 g/4.2 oz), Slight pull out w/ dive test
CoG: 110 mm *850 mAh battery (78 g/2.8 oz)
Power Train
Motor: Powerline Micro 1025 F5J
ESC: Castle Creations Phoenix Edge Lite 50 *BEC not used
BEC: Castle Creations BEC 10 AMP *Set to 7.4 v
Spinner: HyperSpinner Power 32 mm *5 mm shaft, 0 degree prop twist
Prop Blades: GM 16 x 8 F5J
Battery: Turnigy A-Spec 3S 1300 mAh 60C *120 g/4.2 oz (not included)
Servos
Ailerons: Blue Bird CB-1005HV
Flaps: Blue Bird BMS-A54H
Aileron & flaps servos installed with wooden servo frames
Elevator: Blue Bird CB-1005HV
Rudder: Blue Bird BMS-105HV *New version of CB-1005HV
Receiver: FrSky X8R
Control Surfaces Throws
Ailerons Up: 20 mm
Ailerons Down: 12 mm *Aileron differential mixing used
Flaps Up: 6 mm *Aileron to flap mixing used
Flaps Down: 4 mm
Elevator Up: 12 mm
Elevator Down: 12 mm
Rudder Left: 45 mm
Rudder Right: 45 mm
Aileron to Rudder Mix
Aileron Up: 20 mm
Rudder Left: 25 mm *Rudder Right is same
Wing Entire Trailing Edge
Reflex: up 2 mm *Speed mode
Neutral: 0 *Cruise mode
Camber: down 4 mm *Thermal mode; slider 2 mm to 6 mm down
Landing/Crow
Ailerons Up: 10 mm *Reverse differential used
Flaps Down: 60 degrees
Elevator Down: 7 mm
For Sale New Pike Perfection F5J/ALES ak79 Aircraft - Sailplanes (FS/W) 4 Apr 13, 2016 07:50 AM
Discussion F5j Option: Super Ava Pro or Pike Perfection baum58 Electric Competition Soaring-F5J/ALES/e-Soaring 3 Dec 30, 2015 05:39 PM
Sold Re List new unbuilt Pike Perfection F5J Light Jim Frahm Aircraft - Sailplanes (FS/W) 0 Mar 09, 2015 04:41 PM
Sold Perfect Pike Perfect! F5J/ALES SkipMillerModels Aircraft - Sailplanes (FS/W) 1 Feb 03, 2015 04:14 PM
Sold Perfect Pike Perfect! F5J/ALES SkipMillerModels Aircraft - Sailplanes (FS/W) 3 Jan 22, 2015 11:12 AM
