Many Items, Charger, Ride Along Screen, RTF Quads. Getting out of the hobby. - RC Groups
This thread is privately moderated by JustAGuy, who may elect to delete unwanted replies.
Jan 03, 2018, 01:31 PM
Trader Rating: 4
For Sale
Well, it is that time for me, I'm getting out of the entire RC hobby. I have been previously active on this board, but not recently.
I have many items to sell, and I will negotiate price. If I package something together, I will not split it up.
Payment is to be made by PayPal for everyone's protection, I will not take any other form of payment.
Shipping is a fixed charge based on the USPS Flat Rate boxes. If you are in the OKC Metro, pickup is available. I will take additional "Proof of Availability" pictures if needed to verify that I have the items in question.
If your item(s) can fit in a 9x2x6 box, cost is $7.15, 11x6x9, cost is $13.60, 12x6x12, cost is $18.85. If the items you order can fit in one of the standard USPS boxes that are not Flat Rate, we can discuss costs, but minimum is always going to be $7.15 because that's the lowest charge for USPS Priority. I am open to discussing USPS First Class for small packages, but you will waive the protection of Priority.
All items are pictured below, if you would like more detailed pictures, PM me.
ProgressiveRC Sidekick Ticket Combo charger. (Link) Contains an iCharger 206B and a P350 power supply in a hard case with charging deck and built in fan. Includes 4X Fused Balance Board, XT60 to JST Adapter (2), XT60 to FatShark Barrel Adapter, Pin to FatShark Barrel Adapter, Aligator to Pin Adapter, ProgressiveRC prices this at $315, I'm offering it for $115 including shipping.
FR632 Diversity Receiver adapted to use JST plug 2S Battery, I used a FatShark battery, you can use any 2S with a JST plug. Attached is a VAS Crosshair, and a VAS Omnidirectional antenna, with a 12' analog video cable to connect to the FatShark goggles. Both antennas are RHCP. The FR632 retails for around $50, the Crosshair for $45, and the Omni for $23. The whole set is mounted to a selfie-stick cell-phone frame, and I have the stick that went with it as well. A FatShark 2S battery adapted to JST is also included. The package is available for $40.
Eachine Diversity Ride-Along Screen Receiver. 7" screen with built in diversity receiver and sun shield. Adapter for 2S JST plug battery included to supplement the internal battery. AC Charging Adapter included, protective case included. Banggood sells this for $95 (Link) and I've only used it indoors to do camera configuration and other such tasks, so I'm selling for $60
Batteries:
ReadyMadeRC - 1500mAh 60c XT60 (15 Charge Cycles, 4 Avail.) - $10 Each, 1000mAh 60c XT60 (15 Charge Cycles, 2 Avail.) $5 Each.
Tattu - 1300mAh 45c XT60 (15 charge Cycles) $8, 1500mAh 45c XT60 (15 Charge Cycles, 2 Avail.) $10 Each.
SPECIAL DEAL - EVERYTHING BETWEEN HERE AND "FULL QUADS" FOR $120 Shipped. No, I will not separate, this is a package deal.
5.8Ghz Antennas, standard issue - 7 available at $1 each.
TBS Triumph RHCP Antennas - 3 Available at $15 each
RunCam 2 Orange Color with 3D Printed Lens Cap, never used, no MicroSD included, extra battery included, battery charger included (Pictured with Fatshark Goggles), accessories included - $60
Xiaomi Yi Action Cam Black Color with 2 extra batteries and USB Charger, 1080P/720P version, NOT 4k, no MicroSD included, no accessories - $40
RMRC Lipo Tester, up to 6S - $2
FrSky SmartBus Lipo Battery Sensor with LCD display - $15
Matek PDB-XT60 Power Distribution Board for MicroQuads - $5
OpenLog (4 Available) - $3 each
OpenLager (2 Available) - $20 each
MinimOSD Micro with Pinheaders (2 Available) - $2 each
FX799T VTX with antenna pigtail - $10
FX799T VTX adapted to connect to Foxeer, RunCam, and Xiaomi cameras for testing - $10
AngryBeez XM20 20A ESC including case (Never used, 4 Available) - $5 each
ReadyMadeRC 8 LED Addressable board with passthrough (new, 4 available) - $3 each
ReadyMadeRC 4 LED + Buzzer adressable board with passthrough (New) - $3
ReadyMadeRC 4 LED + Buzzer adressable board with passthrough (Used) - $2
Buzzer, standard 12v (New) - $1
Buzzer, standard 12v (Wired) - $0.50
SMA to 90deg SMA pigtail (1 available) - $1
SMA pigtail with reinforced insulation - $1
90deg SMA adapter - $0.50
Prop Balancer - $1
Misc CF Parts - $1
MRM 250 V3 Quad Frame, may be missing accessories, but I think they're all there. $10
ProgressiveRC 6S Balance Board and Adapter Cable. $5, or included with a larger purchase.
3D Printed RunCam 2 mount for 250mm frames, black. $1
3D Printed Fatshark Covers for LaForge Diversity Module, black. $1
DALProp T5045 (Sets of 4)- Solid Blue -1, Solid Black - 4, Translucent Blue - 4, Translucent Purple -3, Translucent Red - 4 ($3 per set)
DALProp T3045 (Sets of 4)- Solid Black - 1 ($3)
DAL Prop 10x45 - 8 Mixed CW/CCW blades, some with tip damage. ($2 for all)
RaceKraft 5051 (Sets of 4) - Translucent Green - 7 ($5 per set)
Full Quads.
Shendrones Butters Frame, Naze32 Rev 6 FC, Matek PDB, DYS BX1306 4000KV Motors, AngryBeez XM20 ESCs, DALProp 3045 Props, AngryBeez FX799 VTX, Foxeer HS1177 FPV Cam, FRSky X4R-SB RX, MinimOSD Micro, OpenLog. Frame has been repaired once, not in a structurally important section. $100
MRM 250 Frame, BrainFPV FC with Baro addon (Tester Version), Brain FPV RE1-mPB PDB, DYS SE2205-2300KV Motors, AngryBeez XM20 ESCs, DALProp 5045 Props, AngryBeez FX799 VTX, Foxeer HS1177 FPV Cam with 2.1mm Lens, FRSky XSR RX, OpenLager, TBS Triumph RHCP VTX Antenna, 4x Addressable 80-LED Strips, 1x 4-LED+Buzzer Board, XT60 Pigtail, 3D Printed RunCam2 Mount, 3D Printed Foxeer HS1177 Mount. $150
Martian 255 Frame, Seriously Dodo F3 Rev 3b FC, Seriously Doge OSD, Matek PDB, DYS SE2205-2300KV Motors, AngryBeez XM20 ESCs, DALProp 5045 Props, AngryBeez FX799 VTX, Foxeer HS1177 FPV Cam with 2.1mm lens, FRSky X8R RX, MinimOSD Micro, OpenLog, TBS Triumph RHCP VTX Antenna, 3D Printed RunCam 2 Mount. 3D Printed Foxeer HS1177 Mount, XT60 Pigtail. $100
Alien H4 450 Folding Quad Frame (Link), APM 2.8 FC, Matek PDB, Sunnysky V2216-900KV Motors, AngryBeez XM20 ESCs, 10x4.5 Props, GPS Antenna, 3-Axis Gimbal For GoPro or Xiaomi Yi Action Cams (Link), AngryBeez FX799 VTX, Foxeer HS1177 FPV Cam, 2x FRSky X8R RX in 16-Channel mode, MinimOSD, XT60 Pigtail. $300
Sold Items
Code:
XT60 Pigtail (2 available) - $0.50 each
Mini RTF LC-Filter AMP 2-4S Power Filters (Link) (New, 2 Std) - $1 Each
2.5mm replacement lens for Foxeer HS1177 - $1
2.8mm replacement lens for Foxeer HS1177 (1 Avail.) - $1
ShenDrones Butters Frame, new in package, never touched. Retails for $90. Offering at $30
DYS Race Edition SE2205-2300KV Motors (New, 4 Avail, CW) - $3 Each
EMAX Cooling MT2204 II-2300KV Motors (Flown 4 times before replaced, 4 Avail, 2 CW, 2 CCW) - $2 each
5100mAh 35c XT60 (5 Charge Cycles) - $20
Foxeer HS1177 FPV Camera with stock 2.8 lens and bracket - 1 available, no wiring included, comes with control/video out interface cable - $8 each
Foxeer HS1177 compatible lens, either 2.5 or 2.1, $1
Unknown super-micro FPV cameras (2 available) - $2 each
FRSky Taranis X9D Plus with included Multimodule expansion card. Multimodule is OSD integrated, all configuration is done via the Taranis interface. Antenna mount for the multimodule integrated behind the stock antenna mount.  Stock Taranis metal case included, antenna for Multimodule included, neck strap included. Charger NOT included. I can't find the charger after I cleaned my workbench, but any 12v source will work to charge the included battery. The throttle gimbal has been adjusted to remove the "Click" but it's a simple matter of tightening a screw to change that. All switches, buttons, and gimbals are fully functional. It looks like these are retailing for about $190 now, I can let this one go for $130. Price Adjusted: $100
TinyWhoop with BeeBrain FRSky FC, eachine frame and rotors, 3D Printed camera mount, FX798 Cam/VTX combo. Comes with 6 MyLipo.de 205mAh 25C/50C batteries, a RockstarAlchemist 3D printed case, and a 6x balance board with an XT60 plug. Batteries have been cycled 6 times each, and kept at storage since I last flew. Asking $70
MiP Hex Drivers, sizes 2.0mm, 2.5mm, and 3.0mm. These retail for $15 each, I am selling these lightly used tools for $20.
Offbrand Hex drivers, sizes 2.0mm, 2.0mm, 2.5mm, 3.0mm. What I used before I got the MIP, $5 for the set or I'll throw them in with a purchase of a larger item.
3D Printed Foxeer HS1177 mount for 250mm frames, black (2 avail.). $1 each
RTF 1V-17V Adjustable Voltage Regulator (Link)(New, 8 Micro) - $1 Each
TP-Link 2.4Ghz extended range antenna for FRSky Taranis replacement with pigtail. I never got around to modifying the antenna setup on my Taranis, but this is all you need. $5
3D Printed Antenna mount for XSR/X4R-SB type antennas, black (3 hard mount, 3 stick-on). $1 each
3D Printed Antenna Nuts (4 avail.) - $0.10 each
Stone Blue Airlines Jet Fuel battery straps (7 avail.). $0.50 each
RMRC battery straps (1 Short, 2 Med, 2 Long). $0.50 each
FRSky XSR RX (No Packaging), wiring harness included - 1 Available at $10 each
FRSky X4R-SB (New in Package) - 2 Available at $15 each
FRSky X8R (No Packaging) - 1 Available at $15
MicroMotorWarehouse TinyWhoop Motor Set, 2 CW, 2 CCW. Speed: Fast (15k). $15
Eachine TinyWhoop Props (Red), set of 4, 2 CW, 2 CCW. $5
Stock Blade Inductrix Props (White), set of 4, 2 CW, 2 CCW (2 Avail.). $3
Stock Blade Inductrix Frame, new in package. $5
Stock Inductrix Motors, lightly used, set of 4, 2 CW, 2 CCW. $3
Blade Inductrix Controller, from my original Inductrix purchase. $15.
FatShark Dominator HD2 Goggles with 2.5 Diopter lenses, additional foam face pad, data cable, mono-earbud, case, and battery. Goggles are in very good condition, screens have never been exposed to sunlight, fan is fully functional. No receiver integrated, no MicroSD Card included, includes Trinity Head Tracker already installed. As far as I can tell, the HD2 is still selling for around $450, and the Trinity Head Tracker chip for about $45. I'm selling the both of them together for $300.
Antennas for FRSky XSR - $2 for a pair.
45deg SMA adapter (4 available) - $1 each
ArduCopter Radio Telemetry 915mhz modules, USB and ArduCopter interfaces - $5
Eachine Cam/VTX combo for Tinywhoop - $5
NAZE32 Rev6 FC in Case (Never used, 90deg Pinheaders) - $5 (Sold one, found another one.)
SP Racing F3 Evo FC (Never used) - $10
Matek Power Distribution Board with VTX and Cam outputs - $10
Unopened Martian 255 frame. As the name implies, it is a 255mm quad frame. Review Here: Link Banggood sells it for $25,I'm after $5.
Last edited by JustAGuy; Yesterday at 12:51 PM. Reason: Price Adjustments and Sold Items
Jan 03, 2018, 04:34 PM
Trader Rating: 16
shen13's Avatar
im interested in some small items?how about shipping on these?maybe envelope size/?
Jan 03, 2018, 05:59 PM
Trader Rating: 4
Depends on how many and what kind of packaging you want them in. PM me with specifics please.
Jan 03, 2018, 11:22 PM
Trader Rating: 7
PM'd with list... Thanks
Jan 04, 2018, 02:16 PM
Trader Rating: 0
interested in a TBS antenna and the XSR (if never used)
Jan 04, 2018, 03:06 PM
Trader Rating: 25
Interested in the cased NAZE32. PM sent
Jan 10, 2018, 02:10 PM
Trader Rating: 4
I have updated the post to reflect adjusted prices.
All sold items have been moved to the bottom of the post.
Jan 15, 2018, 06:30 PM
Trader Rating: 8
Pm'd ...
Jan 17, 2018, 10:44 AM
Trader Rating: 4
All prices updated, if you want a bunch of the small stuff, I will do a deal for whatever fits in a USPS Small Flat Rate box.
Jan 19, 2018, 04:55 PM
Trader Rating: 0
PM sent :-)
Jan 19, 2018, 09:16 PM
Trader Rating: 92
Often wrong ("wife")
johnbyrne's Avatar
PM sent
Jan 21, 2018, 12:05 AM
Trader Rating: 162
visioneer_one's Avatar
Interested in several small items... PM sent.
Yesterday, 12:53 PM
Trader Rating: 4
I have adjusted the post for sold items, and added a special deal.
