Jan 03, 2018, 12:36 PM
multiplex easy glider pro
I just bought a used easy glider and while going over it at home I find the rear fuselage is bent out of straight. It,s only about a1/4 inch out and is very gradual but the vertical fin is not lining up with the fuse center line. My question is how can I bend the Elapo foam fuse back this small amount? I am guessing it was stored out in the Florida sun too long. Thanks.............Ted
Jan 03, 2018, 01:38 PM
Xpress..'s Avatar
Gently bend it back past center in the opposite way, but only in little increments. Eventually it will bend back straight. Don't bend it too extreme or you may end up tearing the foam. You don't want to use heat or anything other than just bending it yourself for this task.
Jan 03, 2018, 08:21 PM
elapo foam
Thank you Express, that is all I need to know. A wooden U shaped adjustable box to store it in should work..........Ted
Discussion Multiplex Easy glider PRO Bleriot Foamies (Kits) 3613 Nov 11, 2018 09:11 AM
Discussion Multiplex Easy Glider Pro Cocksie46 Electric Sailplanes 3 Jan 24, 2009 09:20 AM
Discussion Multiplex Cularis vs. Easy Glider Electric (Pro) Led Zeppelin Foamies (Kits) 3 Nov 10, 2008 02:52 PM
New Product Multiplex Easy Glider PRO# *********** Joe Pierson Electric Sailplanes 62 Aug 01, 2008 11:28 PM
