How to make hot foam wire cutter and a CG balancer - RC Groups
This thread is privately moderated by TommyClancy, who may elect to delete unwanted replies.
Jan 03, 2018, 04:10 AM
TommyClancy's Avatar
This is a multi functional tool a hot wire foam cutter and cut any foam into various layers you want for your aircraft and it can also be used to check your COG..
The wire is adjustable to the width you want to cut for your foam watch this video to see how I made it
How to make a hot wire foam cutter and a CG balancer (7 min 42 sec)
Discussion Hot Wire Foam Cutter powerlinemanco Foamies (Scratchbuilt) 14 Jan 28, 2018 06:36 PM
Discussion Hot wire foam cutter problems TarikAgcayazi Foamies (Scratchbuilt) 5 Dec 11, 2015 04:33 PM
Discussion Making your own planes with a CNC hot wire foam cutter dberladyn Foamies (Scratchbuilt) 14 Aug 20, 2009 11:14 AM
Discussion Need advise making hot wire foam cutter Fuelman DIY Electronics 7 Nov 22, 2008 12:04 PM
Discussion how to make hot wire foam cutters Yellow Baron Foamies (Scratchbuilt) 2 Oct 08, 2007 10:28 AM
