Amimon CONNEX Wireless Mini HD Video Link - RC Groups
This thread is privately moderated by Cuba59, who may elect to delete unwanted replies.
Jan 03, 2018, 12:55 AM
Trader Rating: 13
$930.00 USD
Buyer pays shipping
For Sale
Cleaning the Hangar. Found a almost new Amimon CONNEX Wireless Mini HD Video Link, 1 1/2 month new
all cables included, comes like new in box
1080p60 Video Monitoring from the Air
HDMI Input and Output
3 Ground Antennas - Up to 1600' Range
Less Than 1 ms Latency
5.8G Operation To Avoid Interference
Relays S.Bus / PPM Gimbal Controls
Supports OSD for MAVLink Telemetry
AES128 / RSA1024 Video Encryption
Compact - Air Unit Weighs 2.1 oz
Supports Up to Four Receivers
Link https://www.amimon.com/connex-uav-market/connex-mini/
Amimon's CONNEX Mini features the same 1080p60, zero-latency performance as the standard CONNEX, but in a scaled form factor and with a line-of-sight range of 1600'. Both the air and ground units have been reduced in size. The Air Unit weighs just 2.1 ounces, making ideal for smaller UAS, such as those carrying action cameras like a GoPro or compact mirrorless cameras like the Panasonic GH4.
The Air Unit incorporates a micro-HDMI input and includes an adapter cable suitable for a GoPro with HDMI output (cables for other cameras available separately). On the Ground Unit, there is a standard HDMI output for connecting FPV goggles, a field monitor, or other monitoring or recording device. For applications where several users require a their own video feed, up to four ground receivers (available separately) can be linked with one Air Unit.
Plug & Fly
CONNEX Mini is designed to setup and get you working out of the box – no complicated binding procedures here
Full HD Resolution
Unlike analog systems, which limit you to SD resolution, the digital CONNEX Mini system provides support for up to 1080p60
Virtually No Latency
Featuring less than 1 ms of latency, the CONNEX Mini does not buffer or hold your video, so you can see and control what's happening live. Use CONNEX Mini video to help you fly, aim the camera, or operate the gimbal
5.8G ISM Band Operation
CONNEX Mini uses the 5.1 to 5.8 GHz frequency range to avoid interfering with aircraft control systems, which are usually 2.4 GHz. Automatic Frequency Selection (AFS) will choose the best available channel to be used and move seamlessly to an alternative channel on-the-fly if needed
Gimbal Control
CONNEX Mini is able to relay the control signal for an S.Bus- or PPM-controllable gimbal mounted on the UAV. A dedicated transmitter for the gimbal can then be connected to the Ground Unit via its 2.5mm transmitter port. PPM and Futaba (S.Bus) trainer port adapter cables are provided
OSD (On-Screen Display) Overlay
CONNEX Mini On-Screen-Display (OSD) is a great way to see your flight status. The OSD shows both information about your wireless link status, and telemetry from your UAV flight controller. It works with MAVLink- and CAN-Bus-based telemetry modules (available separately)
Multicast Function
The CONNEX Mini can transmit to up to four ground units simultaneously – great for applications where multiple users require a dedicated video feed (addition ground receivers available separately)
Encrypted Transmission
CONNEX Mini employs AES128 for the video encryption and RSA1024 for key exchange to help ensure no one unauthorized is able to intercept your video feed
Management Software for Mobile and Desktop
Access advanced setting and update firmware. The CONNEX management software is available for Windows, OS X, and Android
Air unit (transmitter)
Ground unit (receiver)
JST 4-Pin to XT-60 Power Cable
JST 8-Pin to CAN-Bus / S.Bus Telemetry Cable
JST 8-Pin to MAVLink / S.Bus Telemetry Cable
2 x Stern Antenna with R/P SMA-35
R/A Micro (GoPro Back facing) to L/A Micro (50 cm)
Micro-USB to USB Type-A Female (OTG Cable)
Micro-USB to USB Type-A Male
Touch-Fastener / Tie Wraps for Mounting
Antenna Clips
DC to XT-60 Power Cable
2.5mm to PPM Cable (non-SBUS RCs)
2.5mm to Futaba Trainer Port Cable
3 x 2 dBi Antenna R/P
Price $950 or offer (still with warranty)
Shipping from Miami
Sold Amimon CONNEX Wireless Mini HD Video Link Cuba59 Aircraft - General - Radio Equipment (FS/W) 1 Jan 27, 2018 01:11 PM
For Sale Amimon CONNEX Wireless Mini HD Video Link Cuba59 FPV Equipment (FS/W) 0 Dec 20, 2017 11:30 PM
For Sale Reduced! Connex Amimon Wireless HD Video Link for UAVs BNIB slotimport Aircraft - Electric - Multirotor (FS/W) 3 Nov 06, 2017 02:53 PM
For Sale Amimon Connex Wireless HD Transmitter and Receiver Kit 78Targa Aircraft - Electric - Multirotor (FS/W) 8 Apr 24, 2016 07:11 PM
Discussion Amimon Connex Wireless HD Discussion Thread SamurAchzar Multirotor Drone Talk 0 Apr 05, 2015 03:20 AM
