This thread is privately moderated by FPV.Model, who may elect to delete unwanted replies.
Jan 03, 2018, 01:19 AM
New Product
Feather SX-220 Racing Quad
Feather SX-220 is a light and durable frame made of Japanese 3K carbon fiber. It features an easily removable camera housing mount that allows the user to access the interior of the frame to preform basic maintenance on electronic components. The side panel camera mounts for your FPV camera can be adjusted from 10-60 degrees to allow for a camera angle that can suit both beginner and experienced pilots. The camera protection housing also works double duty and can be used as a 30 degree mount for you HD action cameras.
The interior arm nuts are pressed into the carbon fiber by using pressed nuts were able to achieve a simplistic design that looks nice and has a use. The screws for the arm placement can easily be removed and allow for very easy arm removal in the event that one might need to be changed. Feather SX-220 weighs in at 86.5 grams. This includes all bolts, nuts, standoffs and the sma glass fiber antenna mount. Such a light weight will help you shave off plenty of grams in your racing build.
Feather SX-220 is also our first quad to be backed with a one year warranty against defects and broken parts. Please have a look at our 1 year replacement warranty that protects you from broken carbon fiber that may occur to your quad within its first year of use.
Features:
  • Made of Ultra High Quality Japanese 3K Carbon Fiber.
  • Camera Angle can be Adjusted Between 10~60 Degree.
  • FPV/Action Camera Mounts.
  • 30 Degree Mount for HD Action Cameras.
  • Glass-fiber SMA mount.
  • Turtle mode Compatible.
  • Replaceable Arms for Easy Installing and Reparing.
  • Only 86.5g includes all bolts, nuts, standoffs and the SMA glass fiber antenna mount.
Mini-Review First FPV quad. RS-220 Racing Quad with Furibee VR01 Goggles. I'm new to FPV. hifinsword FPV Aircraft 16 Sep 04, 2017 05:59 AM
New Product Hornet 220 Racing Quad (At Armattan Productions) RotoRex Mini Multirotor Drones 32 Feb 26, 2017 08:39 AM
