Jan 03, 2018, 12:07 AM
rsrguy3's Avatar
Scorpion
I have an older Scorpion commander esc (programming card uses dips) and the 3008-32 brushless. I've installed the combo into a new fixed wing airframe. On several occasions at power up it has continued beeping a single tone alarm after what I'd assumed was an arming chime. On a couple of occasions I observed a two tone alarm.
First things first.
1. I checked adjusted and rechecked my throttle trim.
2. I used freshly charged "nown good" lipo''s
3. After all 4 attempts at custom and factory default programming, I calibrated throttle after fist power up (on fresh binds)
4. The only luck I had getting it to proper function (sans-alarm) was after reversing the throttle channel, then resetting it to normal. The issue with this was it wouldn't stay locked in for subsequent power ups.
What am I missing ? I know this is supposed to be a quality product, and I'm looking forward to flying, but it's just irritating the he'll out of me. I'm hoping it's something simple, even if that means I look like an idiot on RC groups.
Regards,
Guy
Jan 03, 2018, 06:47 AM
Is the throttle trim all the way down?
Jan 03, 2018, 08:16 AM
An itch?. Scratch build.
eflightray's Avatar
Try a google or whatever you use search on -- Scorpion commander esc problems ---
Their are a few threads in various forums.
Jan 03, 2018, 08:36 AM
rsrguy3's Avatar
Trim was set to three positions including all the way down. I've searched rc groups as well as a Google search. I haven't found this specific issue on those threads. The issues I've found on line generally center around the ir programmer or are not the same issue I'm running into. As far as the manuals troubleshooting instruction are concerned, well I'll just say the trouble shooting tree is weak on limbs and branches not to mention leaves.
Jan 03, 2018, 10:36 PM
rsrguy3's Avatar
Messed around some more tonight, went through the reverse throttle servo scenario a couple more times and for some reason it stuck, through a few power up cycles.
Discussion Scorpion ,Turbo Scorpion or Tomahawk ? dadio Off-road Cars 5 Dec 20, 2016 07:53 AM
Discussion Useful new device from Scorpion: the Scorpion Backup Guard. Thomas B Electric Plane Talk 26 Feb 03, 2016 01:37 PM
Alert Scorpion HK2221-10 3000kv outrunner and Scorpion Commander ESC for sale in Acworth SargeAF Atlanta Area RC 4 May 18, 2012 12:25 PM
Help! Scorpion Calc - Deciding which scorpion motor/3 blade prop to use with Kyosho FW190EP cdis Power Systems 9 Oct 15, 2008 08:52 PM
