Jan 02, 2018, 06:00 PM
JulianGoesPro's Avatar
FAQ
Spektrum Quad Race Serial Receiver w/Diversity (SPM4648)
OVERVIEW
The Spektrum DSMX Quad Race receiver provides a high speed serial data connection with up to 20 channels. It's small and lightweight providing an excellent receiver for even the smallest of applications. It also features Auto-Bind so you no longer need to carry a separate receiver to bind. Dual antennas provide receiver diversity for solid signal and the long coax antennas help to provide maximum signal strength in all orientations for challenging installations where carbon fiber, metal and batteries shield the antenna. And with Spektrum DSMX 2.4GHz RF protocol the Spektrum DSMX Quad Race receiver provides unsurpassed range and interference free performance for quad racing.
KEY FEATURES
Antenna Diversity
Auto-bind
Serial port supports Remote/Satellite Receiver
Weighs only 3 grams
11ms speed with exceptional range and interference free operation
Works with most flight controllers including the Naze32, CC3D, SP F3 and more*
*Requires Remote/Satellite connection
PRODUCT SPECIFICATIONS
Type:Micro Serial Receiver
# of Channels:Up to 20
ModulationSM2/DSMX
Band:2.4GHz
Length:1.0 in (26mm)
Width:0.8 in (21mm)
Height:0.3 in (8mm)
Weight:1.3 oz (3.6g)
Voltage Range:3.3V
Antenna Length:2.4 in (62mm)
MSRP: $24.99*
http://spektrumrc.com/Products/Defau...ProdID=SPM4648
Jan 02, 2018, 06:02 PM
Most important things!
- this is a 3.3V receiver (don't feed it with 5V)
- it's a serial receiver and uses the Spektrum Satelite Protocol (don't confuse it with SBUS or SRXL)
- this receiver is the only receiver from Spektrum with auto bind (no CLI command needed)
FliteTest // Build Video with the SPM4648 Quad Race Serial Receiver
FT 270 Quad BUILD | FLITE TEST (1 hr 53 min 22 sec)
click here to jump directly to the installation of the reciever
Jan 03, 2018, 02:52 PM
Kiss FC
Revolt
Jan 03, 2018, 04:39 PM
Can you not connect it to the sbus pad as long as you can configure that uart to Spektrum? It's just a serial rx after all? Right?
That's how it connects on the vortex 230, all rx's connect on the same signal line, you only move the voltage cable to suit your rx.
Jan 03, 2018, 05:07 PM
It depends, the inverter that’s needed for sbus needs to able to be “turned off”, some FCs have an always inverted SBus “pad”, if that’s the case, then it won’t work.
The other thing is, the SpekPot is usually located next to or is including a 3.3V pad which is needed for those kind of “receiver/satellites”
Jan 06, 2018, 12:29 PM
Thanks to Chris I got pics of how he mounts his! Looks nice decased and the antenna pointing in one direction
Feb 08, 2018, 08:05 PM
Savage Rather Than Average
3bigdirtdiggers's Avatar
I have one of these receivers and it's working great with my old first gen dx7 but my friend ran one of these with the same antenna setup but with a dx7 g2 and it was always failsafing and he also tried a dx8 g2 and that didn't work either. We could fly at the same spot with the exact same setup and his would failsafe and mine wouldn't. I guess the difference was dsm2 dsmx but I thought dsmx is supposed to be better . I guess in this case dsm2 was better unless there is some other difference. He tried the new rx Also but with the same results. So he finally went to frsky
Feb 08, 2018, 08:21 PM
No bounce, No play.
davidmc36's Avatar
You say he tried the new Rx. You mean he tried your good working Rx?
Feb 08, 2018, 09:35 PM
No he tried the newer updated spm4649t after this one
Feb 09, 2018, 05:29 AM
His radio most likely was at fault then and needed to be sent back. If he sold it to anyone then chances are they are now flying on a faulty radio if they never check it over and do a proper range check.
While Spektrum might not penetrate as well as some other brands both the 4648 and 4649 have been good for me on DSMX, well enough to leave the tx in the house and take the rx off for a walk outside and down the street. I'm on EU/UK equipment too. Further tests showed my video dropped way before rado did.
Strangely even though frsky penetrates better, when I tested it in a high interference area, it basically just refused to work where Spektrum didn't seem much affected.
Feb 09, 2018, 07:53 AM
He bought a new dx8 and had the same trouble as his dx7. All the other things he flew with them worked fine
Feb 09, 2018, 09:03 AM
Weird.
Feb 09, 2018, 10:44 AM
a DX8 G2? Weird, did he ever look at the flight log (SPM4649T is so awesome though sure more expensive than the SPM4648... IMO)
BTW there is always the chance of the quad beeing "the problem", have you guys tried to use "your" radio with his quad?
Feb 09, 2018, 03:17 PM
No we didn't try that. Maybe it was his power supply
Feb 09, 2018, 03:20 PM
No bounce, No play.
davidmc36's Avatar
Even something silly like a unnoticed ground loop causing problems.
FAQ New Spektrum DSMX Quad Race Serial Receiver with Telemetry (SPM4649T) czorzella Radios 2649 Dec 18, 2018 06:25 AM
Help! Spektrum Quad Race Serial Receiver w/Diversity KISS FC William Trias Multirotor Drone Electronics 1 Jun 07, 2017 10:06 AM
Help! BRF3 spektrum race receiver Spm4648 Rczorro Multirotor Drone Electronics 0 Sep 21, 2016 03:06 AM
Discussion Spektrum DSMX Quad Race receiver SPM4648 i_am_mark_evans Radios 8 Aug 31, 2016 09:47 AM
