Jan 02, 2018, 02:28 PM
AeroDan
Hobbico: Torqmaster-Mini
I’m considering this 3.6lb.,12V/4.5A battery, w/matching A/C over-night trickle charger, so I can use this to power my 1S Li-Po quad port charger, & charge my Li-Po’s @my site, w/o having to use my car batt. My question is; Is there a special ammeter I need for this mini-battery, to check the voltage, or will ANY ammeter do? I’ll consider whatever you guy’s recommend, because you’ve all helped me before.
Jan 03, 2018, 01:11 AM
Frankenstein recycled packs
rampman's Avatar
Even the free Harbor Freight digital volt meter will be fine for what you are doing.
Amp meaters measure amps but you need a simple volt meter.
Unless you are charging UM cells that battery won't charge many packs.
Rick
Jan 03, 2018, 06:31 AM
What size and how many lipos do you need to charge at the field ? Like Rampman said, you'd only be able to charge a few very small batteries with that.
I'd highly recommend a 4s lipo to power your charger, sized according to your needs.
Jan 03, 2018, 12:05 PM
AeroDan
Rick
Thanks, Rampman. Yes, 1S cells. It’s a quad-port Charger for 1S Cells (Lectron Pro 3.7V180/220 mAh), fixed @0.3A per port (Thunder Power-TP103CQ).
Jan 03, 2018, 12:21 PM
AeroDan
Thanks, Photolad61. They’re 1S, 3.7V, 180/220 mAH ”Lectron Pros”. Charger’s a Thunder Power TP103CQ 1S Quad-Port Charger, fixed @0.3A per port. Considering the HiTec Micro X4 in the future, w/adjustable charge current dials for each port. Awaiting an AOKoda AOK-041 V-meter from Amazon.com. Much more precise than relying on that OLD “Champ” DC field charger’s little red light to blink, to determine how much soup I’m plugging into my Rx. bricks.
Discussion Hobbico TorqMaster 180 Heavy-Duty 12 Volt stratoblaster Flight Accessories 3 Feb 10, 2017 12:48 AM
Discussion Multi 4 Charger with Hobbico TorqMaster LC 12V 7A bryadelm Revolectrix 1 May 03, 2010 09:33 PM
Discussion Charging Hobbico TorqMaster techguy Batteries and Chargers 1 Sep 12, 2008 04:05 PM
Discussion charging hobbico torqmaster lc battery via superbrain 977 istandalone Batteries and Chargers 2 May 10, 2008 08:39 AM
Question about storage of Hobbico Torqmaster "Gel Cell" battery kizzy Batteries and Chargers 12 Oct 26, 2005 12:26 PM
