Jan 01, 2018, 08:33 PM
Depron problems
Hey Guys
I'm building a Depron indoor 3D biplane ( Chinese kit) and need to hinge surfaces with tape. I've tried a bunch of different tapes and nothing sticks.
The instructions call for glue tape that I have never heard of in 30+ years of modeling. I have super sticky hinge that I use for sailplanes but its to stiff and heavy. Weight is a factor on a 150g airplane'
Thanks in advance for the help
Ed
Jan 01, 2018, 09:09 PM
Altitude is my friend...
Depronicus's Avatar
Blenderm has always worked well for me on Depron.
Get the 1" wide version:
Blenderm
However, 3M may have discontinued it.
3M Direct
Good luck.
Jan 01, 2018, 09:35 PM
PapaTrey
PapaTrey's Avatar
You can also put down a VERY thin layer of glue and let it almost completely dry. The tap will stick....I promise.
Jan 02, 2018, 04:41 AM
3d pilot
I use blenderm as mentioned above but it's weird no where locally carries it . I had to order it off amazon . Just make sure it says blenderm . There are several different tapes that look like it .
Jan 02, 2018, 03:14 PM
Xpress..'s Avatar
Yes, use Blenderm tape. It is translucent and has a very smooth texture on top. I have built dozens of foamies over the years and they are all hinged with Blenderm (some of these foamies I still have and the tape is still stuck like glue to the foam). We also use it with giant scales to seal hinges, very versatile stuff and comes in handy for small field repairs to both airplanes and people
Jan 02, 2018, 03:31 PM
Happy Flying
mdtang's Avatar
I have plenty of 1/2" Blenderm tape still in stock if anyone needs. I sell 3 rolls for 12 shipped and Will throw in a 4th roll FREE.
https://www.rcgroups.com/forums/show...-4th-roll-FREE
Discussion Anyone having problems with rcfoam depron lately? burkefj Foamies (Scratchbuilt) 96 Jan 20, 2017 06:51 PM
Help! Anything made from Depron 3/6mm with existing Motor man1ac Foamies (Scratchbuilt) 7 Sep 18, 2015 05:06 AM
Discussion Flite Test plans and 6mm Depron aritchie71 Foamies (Scratchbuilt) 3 Sep 15, 2015 02:33 PM
Discussion Foam unsafe glues or depron problems twinkle Foamies (Scratchbuilt) 18 Jun 27, 2012 02:44 PM
Question painting depron problem biggles8 Foamies (Scratchbuilt) 10 Feb 18, 2010 03:23 AM
