Jan 01, 2018, 05:16 AM
Garage door tore apart HK EZ Master, looking for replacement
Hey guys my garage door tore apart my HK EZ Master - I stupidly hung it too close to the drive chain & that was that.
Its my only plane at the moment so doing repairs but its pretty bent up so wont fly too well.
Im looking for a replacement to use all its electronics in as they are all still fine. I wouldnt mind scratch building a foaming (Have access to XPS & foamboard) but not sure what would be the right size to build. Im looking for something more aerobatic.
Im in Australia so shipping a kit over is too expensive.
Here are the specs:
Specs:
Wing Span: 800mm
Length: 660mm
Flying weight: 340-380g (with battery)
Motor: 2208 1350KV Brushless Outrunner
ESC: Turnigy 12A
Propeller: SF 7x5
Servos: HXT500
Batts: 3s 800mah
Jan 01, 2018, 10:27 AM
If Toads could Fly...
JFord2's Avatar
You might try a Quasar...
I successfully built a 20" Quasar using similar components, and it will fly slow or fast, your choice!
Easy and quick to build, looks good, flies great... See post #93 for mine, but you should read the whole thread...
https://www.rcgroups.com/forums/show...7#post38904246
Jan 01, 2018, 10:54 AM
Retired CAD guy
birdofplay's Avatar
Wow I haven't seen a Garage door opener with an EXPOSED chain for 30 yrs !!!
dave reap has sooooo many great foamy designs for Delta and FW stuff.
Deciding which one is Half the FUN !
Discussion The correct CG for Hobbykings Mini EZ Master asesso Beginner Training Area (Aircraft-Electric) 2 Jul 30, 2017 09:05 PM
Discussion Looking for a servo for a trap door, max height of 15mm Cereal_Killer Flight Accessories 3 Apr 07, 2016 01:45 PM
Discussion Swiss Army garage door opener dll932 Life, The Universe, and Politics 2 Apr 05, 2016 06:26 PM
Discussion Air leaks on your garage door? RCWorks Life, The Universe, and Politics 16 Nov 17, 2015 12:20 PM
Discussion Looking for replacement canopy mounts for HK-450 g00bd0g Electric Heli Talk 0 Jul 22, 2010 02:30 AM
