DPL8: Can I make a preset for constant voltage? - RC Groups
Dec 31, 2017, 03:28 PM
Question
I'm sometimes in a situation where I'd really like to have my DPL8 output a constant 12V to run some gear, feeding it maybe 10A (most likely less than 5A) for a few hours. My DPL8 is setup in a Pelican-type box with it's 48VDC power supply, so I don't have a 12VDC readily available.
I know this isn't what the DPL8 was designed for, but Is this possible? What would I need in a preset to make this work? While I'm in this fixed voltage preset, can I set a cap on the current?
Jan 01, 2018, 10:12 AM
The PL8 is not designed to be a power supply. 12v power supplies are a plentiful these days. Determine how much current you really need a pickup a supply. Lots of 12v/5A bricks on eBay. The other option would be use a DC-DC converter to go from 48v to 12v and run it off your existing power supply. Lots of those on eBay and Amazon.
Jan 01, 2018, 07:43 PM
Thanks, I figured this was the answer I would get, but hoped it was different. The way my setup is configured right now, there isn't room to add a 12V step down. I'm planning to move it to a larger case eventually, I guess I'll add that then. The point of using The DPL8 would be it is less thing to carry and plug in.
Discussion Rapid voltage drop under constant throttle rsilk Batteries and Chargers 26 Apr 26, 2016 02:59 PM
Question DPL8 when "monitoring" displays different 1S Voltages BVH FMA Direct 3 Jun 29, 2014 12:52 PM
Question Constant voltage for motor/prop tests dmccalmon Power Systems 4 Oct 15, 2012 07:29 PM
Discussion Constant current - Constant voltage chargers DaleM Batteries and Chargers 5 Jan 13, 2007 10:27 AM
