Runcam split mini - HD for micros @15g - Page 5 - RC Groups
May 15, 2018, 12:26 PM
Originally Posted by xanuser
yeah. does it do it when run from usb port for power?
Haven't even though about if it records with USB power?
I'll check. Haven't seen it in the feed though, just in the recordings.
May 15, 2018, 06:46 PM
If clean power / a good SD card doesn't fix it, I'd start to wonder if the main board has an issue and needs to go back.
May 15, 2018, 06:52 PM
We are not men, we are DEVO.
xanuser's Avatar
Max Micro SD Card Supported 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II)
cards i use with split
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
pololu i use
May 16, 2018, 12:13 AM
It even happens on the bench, with the motor not running, so it should be clean. Unless the bec on the vtx can generate dirty power by itself?
I've already written to banggood who replyed extremely politely that they are contacting their reseller.
May 16, 2018, 01:19 AM
Just another user...
And so begins the usual run-around routine! All designed to stall for time and wear you down until you either buy another one or just give up.
May 16, 2018, 08:12 AM
Bama3Dr's Avatar
pololu i use
Thanks for posting the links. I'm planning to put together a build in the next month or so and will probably just go ahead and get the pololu you linked to make sure I don't have any video problems. I've had to try to fix a noisy FPV feed before and it's maddening.
-Dustin
New Product Runcam Split / V2 - FPV + HD Camera nitbeat Aerial Photography 2010 Yesterday 08:53 AM
New Product Runcam Split - Low Latency FPV Camera with Runcam 3 Quality Recording Nickz88 FPV Equipment 7 Jul 18, 2017 06:58 AM
New Product Runcam Split, fpv + HD camera combo! smg24 Banggood.com 9 Jun 16, 2017 05:16 AM
Discussion Runcam Split estho FPV Equipment 6 Jun 12, 2017 05:42 PM
Help! Mini Runcam 650tvl and mini Sony 600tvl, which to buy for my equipment? Tommygunn FPV Equipment 3 Apr 13, 2015 09:58 AM
