Dec 31, 2017, 07:50 AM
magrinsi's Avatar
Castle creatons esc
What do you think about this forma a f5b plane 8s 200\250A ?
This esc has log data?
https://www.lindinger.at/en/?sViewpo...rticle=9705940
Dec 31, 2017, 09:00 AM
The Edge 160 Lite is perfectly fine for an 8S setup.
It has logging data, though Castle logging data is know to show values on the high side.
Dec 31, 2017, 09:22 AM
magrinsi's Avatar
I saw the yge 150hv ..more compact.
But the data log is very usefull.
I hope that the CC will fit in the speedfire2 fuse like width.
Someone has try it up 250A by 4/pole motor ?
Jan 01, 2018, 07:46 AM
I did, on a Neu 1512/2D/6.7. Power over 6kw on a Sergey 17.5x21.5.
Jan 01, 2018, 12:16 PM
magrinsi's Avatar
The 160hv lite is completely configurable by PC ...what timing and other settings for a HET700 2085KV 8S?
Jan 01, 2018, 01:12 PM
As per the NEU website seems to work well (some comments in bold):
Brake Delay: No Delay
Brake Ramp: Immediate (*)
Motor Start Power: 59 - anything from 10-60 can be used, I like about 30
Direction: Forward (*) - adjust as required
Brake Strength: 100
Current Limiting: Disabled
BEC Voltage: 5(not for ICE HV) -irrelevant
Power-On Beep: Disabled
Motor Timing: 0
Data Log Enabled: 255
Vehicle Type: Airplane
Throttle Type: Fixed-Endpoints
Throttle Response: 10 - Only when using a transmitter-ramping, otherwise 5-6
Auto-Lipo Volts/Cell: (lowest setting available) - 4.0V-fixed
PWM Rate: 24 Khz
Voltage Cutoff Type: Soft Cutoff (*)
Current Cutoff Type: Soft Cutoff (*)
Link Live Enable: Disabled (*)
Jan 01, 2018, 01:17 PM
That motor should be nice for sport-flying and the power level such that the motor isnt working too hard. A 2085kv motor could also be used on 9S, and even 10S when the prop is not too big and a lot of power is required (though Im not sure a HET motor sill stay together at high rpm).
The 1512/2D I used on 8S had a kv of 2550.
Edit: are you using a 5.2 gearbox (above was based on a 6.7, but these gearbox are normally not available for retro-fitting, only on complete motors as the motorshaft has the gear grinded on it).
Jan 01, 2018, 02:06 PM
magrinsi's Avatar
I have a kpg 27 4.2:1 and 16x17 rmf slim.
For now I using a 100A ESC HV and 7s near 170A for to use 8s I need the CC 160 HV.
Jan 15, 2018, 03:05 PM
magrinsi's Avatar
But for set the throttle point of my radio using the option fixed end point....how i can do?
Feb 09, 2018, 09:26 AM
Still Noob
Labrother's Avatar
This is from castle link software, i recommend that you use this free software, it explains in more detail the settings:
Fixed-Endpoints will set zero-throttle and full-throttle points to fixed values so that the ESC does not have to learn from your transmitter. If you are using this mode, you will most likely want to change the EPA settings on your transmitter to allow full throttle resolution with the throttle stick. To do this, turn on your TX and set normal mode in the transmitter for a linear throttle curve (0,25,50,75,100). Bring your high side and low side endpoints on your throttle channel down to 25%, plug in the battery pack with the throttle stick at full (it won't start up), then bring your high endpoint back out towards (and sometimes past) 100% until you hear a single tone. Next, bring your throttle stick down to the bottom position and bring the endpoint out from 25% out towards (and possibly past) 100% until you hear the ESC arm. Unplug the battery pack, wait a few seconds, then plug back in and verify that the throttle is working properly.
LaBrother
Discussion Which one you think the better for the job; Castle 90 ESC or Cobra 100 ESC ?? G.F. Beurling Electric Plane Talk 9 Oct 03, 2016 11:02 AM
Help! castle esc phoenix ice lite 75 how to reset error code overtemperature?? BUSCAMINAS Power Systems 5 Oct 21, 2015 09:26 AM
Help! how to determine Kv with a Castle ICE ESC pairadocs Power Systems 18 Sep 18, 2015 01:27 PM
Help! How to Castle Field Link program Castle ESC &BEC RedCaptain10 Power Systems 10 Jan 26, 2015 08:00 PM
Discussion How do I check out used Castle ESC with Castle Link Prof100 Castle Creations 10 Sep 23, 2013 03:41 PM
