ESC booting then resetting when adding throttle - RC Groups
Dec 29, 2017, 06:39 PM
Help!
I recently swapped ESCs from some dead ones to a new set on my Reptile quad, but I'm having a problem where all the ESC boot up fine, but when I give it some throttle the motor stutters and then the ESC reboots. Does anyone know how to fix this?
Dec 29, 2017, 08:46 PM
Usual cause of this is a bad battery or bad battery connection. The voltage is probably sagging when you add throttle which will cause resets.
Dec 30, 2017, 03:14 PM
Welcome to the forum
As mentioned in post #2, poor connections or a bad battery can cause this.
Are the new ESCs the same make and model as the dead ones (and how did the previous ones become dead)? With modern flight controllers there's often an option to specify what kind of output goes to the ESCs -- PWM, Oneshot, Dshot are the ones I can think of -- and some ESCs won't work correctly if they're not designed for whatever protocol is set.
Discussion T28 ESC reset Throttle control wingate Beginner Training Area (Aircraft-Electric) 5 Jul 03, 2017 07:51 PM
Discussion Quad flips out when throttling down and then back up AIR mode Jackintosh7 Scratchbuilt Multirotor Drones 6 May 13, 2017 12:23 PM
Help! ESCs raise motor speed only till 1300 pwm, then constant till max throttle (1850) mbandthegang Multirotor Drone Talk 1 Feb 19, 2017 03:30 PM
Discussion Taranis Frsky Sticky does not seems to reset when flight reset button is pressed ragbak Radios 6 Sep 26, 2016 11:16 AM
Discussion cellshield and the reset when throttle is cut pmdevlin Power Systems 2 Jan 31, 2012 07:25 PM
