Aug 08, 2019, 01:12 AM
It would try out large size high pitch prop also, but you will need low KV motor. Years ago we built a glider for mapping (3,4m wingspan, 4kg TOW, max 4h flight time). To get it to fly more efficiently we used very large prop with high pitch together with the lowest KV motor we could find. The logic being, that slower rotating props (prop tips) generate less drag.
If I remember correctly the best results came with 23X12 prop (I might get it wrong - I would have to look at the actual plane to be sure).
Aug 27, 2019, 11:24 AM
hi naterater,
can you please share the flight parameters of believer uav.
thanks in advance
Nov 16, 2019, 04:43 PM
Dangerous Seagul's Avatar
Folks hi.
I have a Turnigy G46-670 Kv and a Turnigy Plush 60A ESC was going to use them on another project but the question I have for you all is would these be a good motor for the Believer. I'm not as advanced as the majority of you guys and I'm finding it hard to find a suitable motor spec for this build
Do you think the G46-670 Kv motors would be a good motor choice and would you recommend a prop size, please? Jonny
Nov 16, 2019, 08:15 PM
We need to know what battery you want to use.
Nov 16, 2019, 08:22 PM
Zippy compact 25c 5000
Nov 16, 2019, 11:39 PM
Sigh. The number of cells (3s, 4s, or 6s) is the import data we need.
Nov 22, 2019, 05:51 PM
Maker of lawn darts.
Kirdro's Avatar
Originally Posted by naterater
I think the T-Motor 4012-480KV will be just perfect even though it's a little heavier.
Has anyone had a chance to test the 4012's? If so, how did you get them to fit in the nacelle and mount to the wing?
Nov 26, 2019, 05:23 PM
Papa Echo 2S1P / 2 Cell / 7.4V
Nov 27, 2019, 11:57 AM
Jonny,
If you look at the website from HobbyKing https://hobbyking.com/de_de/turnigy-...v-46-glow.html you can see that the motor needs 4-5 cells. Your little battery does not work. You should buy a 5s with min. 6000mAh battery for your motors.
Nov 27, 2019, 05:35 PM
Jonny,
Papa Echo thank you for the advice do you the motors are too big?
Nov 27, 2019, 08:08 PM
Jonny,
I don't have the Believer, but I think the Turnigy G46-670 Kv is a little big and heavy with 303g.
If you are a beginner, I would recommend that you start with something smaller, like the Bixler 3 from HobbyKing.
Nov 29, 2019, 03:57 PM
naterater hi would you tell me what your best set up for the believer.
Nov 29, 2019, 04:32 PM
Dec 12, 2019, 08:58 PM
Kirdro's Avatar
Got a few 4012's in. They'll fit, barely. Now I just need to figure out how to mount them with no space.
Sent from my iPhone using Tapatalk
Build Log Believer Twin-tractor 1960mm Mapping /FPV Plane - full review / mods / owner's thread Arxangel FPV Aircraft 880 Oct 11, 2019 01:33 AM
Review Great Planes Twinstar EP Review - 47.5" WS Twin Engine Sport Plane kingsflyer Sport Planes 28 Apr 08, 2019 03:23 PM
Data Benchmark Motor and propellers : NEW AVROTO M2814 11S V3 TEST ! catlord Multirotor Drone Talk 30 Jul 25, 2012 07:53 AM
Video gear, surfaces and engine tests of scratch built twin boom plane rcking323 Fuel Plane Talk 3 Mar 15, 2009 09:31 PM
