I realized very quickly in my RC hobby that your servos better work! Years later I have piles of servos from planes that found their "expiration date." After all this time I still check RCGroups.com to make sure I'm using an adequate servo for my application. Here is a story from Servo City that goes over 6 servos and their uses. I have added the specs of each servo and descriptions in the photos for even more info...
This is a question we are asked on a daily basis. The answer depends on your application and numerous other factors. Here is a short list of go-to's among the hundreds of servos we offer. Price, performance or even uniqueness all play a part. Let's take a closer look....
This servo is designed with long-lasting Karbonite gears and a ball-bearing supported output shaft to reduce friction. Excellent performance at an entry level price.
The powerful HS-645MG is the highest torque standard size analog servo offered by Hitec. Utilizes metal gears for high-impact applications.
The HS-785HB servo is unique due to its ability to rotate nearly eight rotations while retaining positioning feedback!
The HS-805MG servo is the beefed up version of the legendary 805BB monster servo! Designed with metal gears and 343 oz-in of torque.
The standard size servo with continuous rotation. Its linear, proportional speed control makes this an excellent choice for compact camera control setups.
This servo is a brushless beast! It's Neu brushless motor, titanium gears and low current consumption provide tremendous durability and longer run-times between charges.
You can find the perfect servo for your project at Servo City.
Thread Tools |
Most servos one might expect a Beginner to use would be in the 9g range.
Latest blog entry: All things that fly.
Pippin how does that affect the servo?
I bought a bunch of the 485hb. but i had some small movement in all of them. it was a grinding noise that occured evry few second. Later i decided to read up about the 485hb and i found out that it was not uncommon that people had failures with these servos. I decided to not use them and replaced them with other servos. Next time i will search for info before i buy a new typ of servo and not just look at specs and price. |
Meh, on these larger servos. Most Hitec servos IMO are just not that good. The HS 82MG and the 225 are horrible. Sloppy and they fail. The 645MG and HS81 are pretty solid and their big winner is of course the 65MG. Now that is a great servo. The rest, not so much.
For the bigger stuff, I use and trust Futaba and JR. |
I have had good results from the larger servos but not the saller ones (HS-65 and smaller). I don;t use anything smaller than HS-85 from Hitec.
My main complaint is the value. Most Chinese servos are excellent at a much lower price. Why is Hitec so much more expensive than other Chinese brands? . |
Thread Tools | |
Similar Threads | |||||
Mini-Review | JJRC H345, a pair of mini drones in a pack that will not disappoint you at all, fun t | LTECNIC | Micro Multirotor Drones | 0 | Dec 27, 2017 11:22 AM |
Discussion | servo gear won't stop spinning and servo horn isn't moving | BartGojjer | Radios | 4 | Jun 29, 2017 07:59 PM |
Discussion | Help with a OS GT33 that won't run | FloridaFlyBob | Engines | 24 | Apr 04, 2016 12:12 PM |
Discussion | Trickle down economics ... The lie that won't die ... | Tim Green | Life, The Universe, and Politics | 405 | Nov 21, 2015 01:36 PM |
Discussion | Servos that won't centre | Berkie | Power Systems | 9 | Nov 08, 2011 04:22 AM |
