Dec 27, 2017, 05:40 AM
Kingkong hex 300
This hex is said to be PNP. Any comments? Also, anybody care to share their set up.
https://hobbyking.com/en_us/kingkong...black-red.html
Thanks.
Dec 27, 2017, 01:26 PM
KarsNL's Avatar
To be honest; it's cheap, but also an outdated model.
A few points I see;
Flightcontroller: CC3D is old and not supported anymore in recent BetaFlight versions.
Frame: glassfiber (not carbon) wich breaks easily, and the whole baseplate is a PDB...
ESC's: old BLheli (non-S) models
So if it's your first drone, I won't recommend it.
But if it's an expansion of your fleet, maybe it's a fun thing to fly
Dec 27, 2017, 01:41 PM
60 bucks PNP.... CC3D can still do the job. Is it still possible to download Openpilot? Or Librepilot?
I have three Spedix MR’s with CC3D on Openpilot, and they fly great.
The main issue really is the baseplate. Break it and you’re screwed.. Still, great price...
Dec 27, 2017, 09:24 PM
I've searched and downloaded Libre pilot. Looking for someone who have success in fine tuning the cc3d included in this hex. Been searching youtube and have no success so far
thanks.
Feb 06, 2018, 09:51 AM
Mr Santos, have you had any success with getting your Hex300 up and flying? I just purchased one, and can not get the motors to arm if it is not connected to OpenPilot. Thanks
Apr 26, 2018, 05:45 AM
Slideways at warp speed.......
kiwi_craig's Avatar
http://drone-nexus.com/openpilot-dow...-for-cc3d-gcs/
May 18, 2018, 07:32 PM
kiwi_craig's Avatar
even though it is setup with 15.02.01, my 15.02.02 GCS opened it just fine and ran the Tx calibration etc just fine, wrote back files etc.
test hovers now, seems okay.
May 19, 2018, 04:06 PM
kiwi_craig's Avatar
Finally got her up in the air, flies really nicely using all the stock settings.
Pumped three 2200 3S batts through it, anyone tried one on 4S ?
Now to get the fpv up and running !
May 20, 2018, 04:44 AM
kiwi_craig's Avatar
Fpv works
May 21, 2018, 02:45 PM
kiwi_craig's Avatar
Seems the stock props are nothing great, high power draw and low thrust compared to other prop brands
https://www.rcgroups.com/forums/show...6040-prop-data
Looking like a set of 5045 BN gemfans might be the go !
May 23, 2018, 08:19 PM
kiwi_craig's Avatar
Prop Swap
based on the low thrust & high power draw of the stock KK props I swapped in a set of DAL 5045 BN (bull nose) props.
only negative is the props are thicker through the mounting section resulting in less total threaded available to hold the prop nuts on. seems okay though and have Loctite'd the prop nuts with low strength Loctite as a precaution.
the DAL blades are noticeably wider through there chord width and thicker in cross section. overall a significantly more "chunky" prop
I used a combo of green and orange props, these are allot more visible when spinning than the stock red KK props which are basically not visible at all.
Hover testing showed the hex to be hovering nicely with at least 10% less power setting compared to the stock props and was more responsive when the throttle is blipped
outdoor test flying this weekend but expect performance gains all round (more thrust at max power, longer flight times and more responsive)
May 27, 2018, 01:30 AM
kiwi_craig's Avatar
man this flies great, bank 2 flight mode - ratitude is plan brilliant, very agile but still self levels.
nice smooth fast agile, I'm sold ! fun machine.
had a goe in bank three - straight rate mode, yeah it's VERY agile !
May 27, 2018, 05:30 PM
Hi!
I bought one hex300 some months ago.
Finally I decided to try to bind it with my Turnigy Evolution and it worked with sbus (it was not easy...).
I pulled in a 4S lipo.
but I never flied a multi, so I'm a bit afraid to try.
Would you recommend I better to start with a mini/micro/indoor to get used prior to destroy me or others ;-) ?
EDIT: I am not an RC guy at the time, so I have like zero experience.
May 27, 2018, 05:44 PM
Good to know!
I think I'll go with a 2S and attitude.
I'll save the 4S for when I know how to fly.
Which 2S LiPo I should pick?
Any suggestion?
I think this one could be a good choice:
https://hobbyking.com/en_us/turnigy-...ack-xt-60.html
May 27, 2018, 07:32 PM
kiwi_craig's Avatar
2S wont have enough power. 3S minimum, flies nice on 1800 - 2200 3S.
I'm on a 2200 3S 4S will give it stunningly good power
Discussion Kingkong 300 HEX to quad? RJQ Multirotor Drone Talk 1 Dec 06, 2017 11:51 PM
Mini-Review LisamRC LS-300 FPV Beetle Hex Build and Review - Gearbest microrcfiend Mini Multirotor Drones 7 Oct 21, 2016 09:05 PM
Mini-Review Kingkong - Hex300 Quick look at a $17 Hex frame + 5040 / 6040 prop data subpixel Mini Multirotor Drones 19 Jun 07, 2016 03:36 AM
New Product 300 lb. PAYLOAD VertiPod Hex commercial drone Pete Bitar Commercial UAV/FPV 1 Apr 05, 2016 02:10 AM
New Product KingKong 300mm Hex TheMadCADer Mini Multirotor Drones 0 Sep 04, 2015 04:53 AM
