Dec 26, 2017, 09:43 PM
Helique's Avatar
What is this?!
Hi All:
Had a crash and, upon inspecting the ESC, noticed the capacitor had been "relocated." I took the shrink wrap off to inspect the connection and this metal plate thing came free along with the shrink wrap. What is the purpose of this thing? Is it a heat sink? The side that was resting on the esc electronics has a thin plastic sheet on it, I assume for insulation or just cushion?
Thanks for your help.
Dec 26, 2017, 10:18 PM
Wintr's Avatar
Yes, that is the heat sink, and the plastic sheet is a heat transfer device, so the heat will be conducted from the transistors to the sink. I may also be an insulator, electricity-wise, but I don't see the need for that here.
Dec 26, 2017, 11:09 PM
I'm All Thumbs
AirBornOne's Avatar
Prolly just a double sided adhesive pad.Not the best conductive arrangement.
J
Dec 27, 2017, 01:13 AM
Helique's Avatar
Thanks for the replies!
Originally Posted by Wintr
Yes, that is the heat sink, and the plastic sheet is a heat transfer device, so the heat will be conducted from the transistors to the sink..
Thatís what I was thinking.
J
Not double sided, just stuck to the heat sink.
Dec 30, 2017, 04:51 PM
I am a nice guy! Really!
The plastic sheet is both an insulator and thermally conductive. It is absolutely needed to keep th transistors from shorting to the heat sink.
Latest blog entry: Nothing
Dec 30, 2017, 04:58 PM
Half the FET,s on the ESC have their metal tab connected to the battery positive, the other half are connected to negative. Leaving out the insulating sheet will cause a short.
Dec 30, 2017, 05:33 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
Have a closer look Mike, the metal tabs of the 6 FETs are to the PCB side, not on the heat sink side.
The heat sink is mounted on the type number side of the FETs.
This ESC could handle more current without plastic sheet.
Unless they don't trust their own soldering not to touch the heat sink.
In the situation you are describing, two separate heat sinks without plastic sheet would give a better controller.
Of course the manufacturer would ruin that advantage by wrapping the controller in heatshrink.
Gelukkig Nieuw Jaar Ron
Dec 30, 2017, 07:31 PM
Right you are, Ron, I see that the metal tabs are not exposed looking closer at the pictures.
Dec 30, 2017, 11:54 PM
Wintr's Avatar
The plastic sheet takes up any air gaps between the transistor cases and the sink, so, no, it wouldn't be cooler without it. A good paste compound would be somewhat better, but that costs more pennies to apply.
Jan 06, 2018, 03:06 PM
Helique's Avatar
Thanks for all the info guys... closing the thread.
Discussion Anyone seen this before? What is this stuff?!?! Alalaheyoo Power Systems 4 Nov 17, 2016 02:58 PM
Question What old car is this and what is fair market value. Thanks sst2000 Nitro and Glow Power Cars 6 Jul 04, 2016 06:30 PM
Discussion What or why is this standard Futaba S148 Servo doing this? G.F. Beurling Beginner Training Area (Fuel) 4 May 22, 2016 04:53 PM
Discussion does anyone know what this is and what its used for? Robert Boudreau Power Systems 7 Mar 25, 2016 11:42 AM
Discussion What Do You Make of This? Putin Doing Some Spanking or what? DLGjunkyard Life, The Universe, and Politics 49 Oct 19, 2015 03:14 PM
