Sep 24, 2019, 07:30 PM
Description:
Description:
Sent from my iPod touch using Tapatalk
Sep 24, 2019, 11:18 PM
Description:
Description:
Sep 25, 2019, 07:22 AM
ospreyhawk's Avatar
Having built many bipes over the years, I can say that covering around cabanes is always a tough (and daunting) task! Nice work Jas...
Sep 26, 2019, 09:58 PM
Thank you very much!
Sep 26, 2019, 09:59 PM
Description:
Description:
Sep 27, 2019, 08:21 AM
ospreyhawk's Avatar
Nice!
Sep 29, 2019, 11:39 PM
Nice!
thank you!
Oct 16, 2019, 12:10 AM
I made a mistake with the rudder pull cable exits in the fuselage. The locations where they exit were open bays which I covered over. So there was no reinforcement structure for the covering in this area. For days Iíve tossed around ideas on how to make a fix. I finally landed on fixing it from the inside out. I cut two 1/4 inch balsa sheets fitted into the bays and drilled exit holes in them for the cables. I first cut a paper test piece and stuck my arm into the fuse from the wing saddle to test it. Then I cut the two wood pieces, drilled and covered the exit holes, and test fit. Sanding to fit and then applied wood glue with my finger.
Pieces to be added.
Description:
X marks where the exit should be.
Description:
When the glue dries Iíll cut the exit hole in the covering.
Oct 17, 2019, 09:25 AM
Cut out covering for rudder cables.
Description:
Cleaned up covering glue residue. Re-mounted servos, elevator and rudder.
Description:
Oct 17, 2019, 01:56 PM
Great work! Decided on a motor and do you already have the fiberglass bits?
I have plans for the larger OK Pilot Christen Eagle and this makes me want to get working on it!
Oct 18, 2019, 01:14 PM
Hi slidewaysgts,
Thank you!
For the engine I have not decided yet, but am leaning toward a 25cc gas motor. I need to weigh the model to verify that would work. Iíve been looking around for specs of other Christen Eagles. What size is your CE? What engine would it use?
Ironically the first purchase for this model was the fiberglass parts and canopy. Those parts are from fiberglass specialties. I am starting to trim the canopy and will mount the landing gear fairings soon. I need to find a good way to mount the cowl. Any suggestions?
Oct 18, 2019, 03:34 PM
The one I have plans for would be a 40cc-50cc size. Its 1/3.7 scale
The Great Planes large version mounts the cowl like below which gives a more scale look.
http://www.greatplanes.com/discontin...a1217cowla.jpg
Oct 20, 2019, 08:03 PM
Billy T
awesome!!!! nothing like bipes
Oct 21, 2019, 07:36 PM
Thanks!
Oct 27, 2019, 11:22 PM
Aileron covering complete.
Description:
Description:
Harold Osborne Plans a67ems Electric Plane Talk 13 Jun 14, 2018 10:16 AM
Discussion 13 inch Christen Eagle design/build Chris3D Scratchbuilt Indoor and Micro Models 24 Aug 02, 2013 03:31 AM
Help! 38% Christen Eagle II build [email protected] Giant Scale Airplanes 4 Apr 10, 2012 01:20 AM
Harold Osborne Plans a67ems Electric Plane Talk 0 Mar 04, 2002 02:17 PM
