Jun 25, 2019, 12:56 PM
Starting to cover with Ultracote.
Description:
Sent from my iPod touch using Tapatalk
Jun 30, 2019, 04:28 PM
More progress. Ultracote is pretty nice as a heat gun takes wrinkles out pretty well. But it also will lift covering out of creases and curl covering at edges.
Description:
Description:
Description:
Jul 02, 2019, 11:18 PM
Bottom wing mostly covered.
Description:
Jul 20, 2019, 11:54 AM
Top wing covered. Getting around some of these curves was difficult.
Description:
Aug 25, 2019, 11:35 PM
Starting to cover fuse.
Description:
Aug 26, 2019, 12:01 PM
Brooklynite In Texas
Hi JAS!
you have been busy I see, I've been looking at the construction it's pretty solid. Keep up the good work!
Sep 02, 2019, 03:13 PM
Originally Posted by donnyman
Hi JAS!
Thanks, buddy!
Sep 02, 2019, 09:37 PM
Owner of CFC Graphics
WOW!
You've come a long way! Kudos!
www.cfcgraphics.com
Sep 14, 2019, 10:58 PM
More covering
Description: Name: IMG_5445.JPG
Description: Name: IMG_5444.JPG
Description: Name: IMG_5443.JPG
Description: Name: IMG_5448.JPG
Description: Name: IMG_5442.JPG
Description:
Sep 16, 2019, 07:16 AM
ospreyhawk's Avatar
Looking good!
Sep 16, 2019, 07:20 AM
Build Fly Crash - Start Again!
onewonders's Avatar
Hinges
Jasbury, just catching up on this thread, this looks sweet!
I noticed something with your hinges that I haven't seen before please enlighten me.
Have you put the ultracote down around the hinge at the same time glued the hinge into place? Are is the black material around the hinges something else entirely?
I've included one of your images for reference.
Doug
Sep 17, 2019, 10:04 PM
Doug
Hi onewonders,
Thanks! The black material you see is the same Ultracote covering material. I cut the hinge slots, then test fit and removed the hinges, then applied a small piece of covering over each slot. I was able to cut the covering and test fit the control surfaces without covering much area. I drilled small pin holes where I could apply the CA glue without getting it near the pivot location. Then I glued in the hinge halves. I actually inserted the hinge pins when I glued the hinges. This provided good alignment. I only got glue in one pin. (I am thankful for de-bonder.)
Later on I covered the remainder of the surface and did not have to be extremely precise with the hinges. Still looks clean. I did the same technique for all the hinges on this model. This is the first time I've tried the technique and I am pleased with the result.
Sep 17, 2019, 10:10 PM
Originally Posted by ospreyhawk
Looking good!
Thank you
Sep 20, 2019, 01:15 PM
Mas cubierta
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Sep 24, 2019, 07:29 PM
Description:
Description:
Description:
Harold Osborne Plans a67ems Electric Plane Talk 13 Jun 14, 2018 10:16 AM
Discussion 13 inch Christen Eagle design/build Chris3D Scratchbuilt Indoor and Micro Models 24 Aug 02, 2013 03:31 AM
Help! 38% Christen Eagle II build [email protected] Giant Scale Airplanes 4 Apr 10, 2012 01:20 AM
Harold Osborne Plans a67ems Electric Plane Talk 0 Mar 04, 2002 02:17 PM
