Jun 29, 2018, 11:32 PM
More bottom wing center sheet.
Description:
Jun 29, 2018, 11:33 PM
Low And Slow 3D Pilot
OliverW's Avatar
Looks great!
Jul 03, 2018, 06:38 PM
Originally Posted by OliverW
Looks great!
Thank you
Jul 03, 2018, 06:40 PM
Lower wing bottom sheeting.
Description:
Jul 06, 2018, 09:05 PM
Building the cabane. It is easy to get some Ďtwistí in the piano wire bends. The plans call for J-clamps. Instead Iím using zip ties.
Description: Name: IMG_4081.JPG
Description: Name: IMG_4083.JPG
Description: Name: IMG_4087.JPG
Description: Name: IMG_4088.JPG
Description:
Jul 06, 2018, 10:03 PM
OliverW's Avatar
Looks good!
Jul 08, 2018, 12:36 AM
Looks good!
Thanks 🙏
Jul 08, 2018, 12:42 AM
Soldering sheet metal for top wing mount. This took a long time to heat the metal with my soldering iron.
Description: Name: IMG_4094.JPG
Description:
Testing wing position. Itís fun to see some progress.
Description:
Drilling holes in top wing and installing blind nuts. Difficult to get blind nuts in the space between the spars.
Description: Name: IMG_4097.JPG
Description:
Jul 15, 2018, 01:13 AM
Planing and sanding bottom wing. Now fits in wing saddle.
Description:
Description:
Test fitting wings reveal the top wing sits slightly rear and high from the cabane. Next milestone is reinforcing the wing center sections and then mounting to fuselage.
Description:
Description:
Description:
Jul 21, 2018, 11:45 PM
Pressing the top wing blind nuts 🥜 into place. The challenge here is the nuts reside under the spars. Later, I epoxied them in place.
Description:
Jul 25, 2018, 09:23 PM
Mounting bottom wing! Plans leave zero margin for the wing.
Description:
Description:
Jul 29, 2018, 10:37 PM
Mounting top wing. Aligned front bolt first and drilled. Then aligned rear bolt.
Description:
Description:
Aug 19, 2018, 10:41 AM
Wing sheeting and sanding
Description:
Description:
Hinge slot cutting
Description:
Mar 16, 2019, 07:01 PM
Some recent progress: fuselage and turtle deck sheeting.
Description:
Sent from my iPod touch using Tapatalk
Mar 16, 2019, 07:12 PM
And some shots of the tail.
Description:
Description:
Description: Name: IMG_4672.jpg
Description: Name: IMG_4674.jpg
Description:
Harold Osborne Plans a67ems Electric Plane Talk 13 Jun 14, 2018 10:16 AM
Discussion 13 inch Christen Eagle design/build Chris3D Scratchbuilt Indoor and Micro Models 24 Aug 02, 2013 03:31 AM
Help! 38% Christen Eagle II build [email protected] Giant Scale Airplanes 4 Apr 10, 2012 01:20 AM
Harold Osborne Plans a67ems Electric Plane Talk 0 Mar 04, 2002 02:17 PM
