Dec 26, 2017, 10:18 AM
The original Flying Pigs Sqd.
Up&Away's Avatar
Question
Reversing shaft
It's been a long time since I've done this. I need to reverse the shaft of a little Emax 2212 motor.
If memory serves me right, I need to remove the c clip, loosen the grubscrew, tap the shaft through to the other side and tighten the grubscrew again.
Right?
Dec 26, 2017, 06:56 PM
Jack
jackerbes's Avatar
After you remove the Circlip you can pull the housing off after a brief contest with the magnets. Then you can remove the grub screw(s) and use a piece of tube or something to localize the forces close to the shaft and press the shaft to flush with the top of the housing. Then you can use a screw or something to press it fully out.
These threads have most or all of the details you'll need:
Replace/modify shaft:
Making-and-Replacing-a-Brushless-Motor-Shaft - https://www.rcgroups.com/forums/showthread.php?1240725
Fitting prop saver:
Prop-Savers-Fitting-Using-Testing-Making-Thera-Band-Bands - https://www.rcgroups.com/forums/showthread.php?1419378
Disassembly:
Outrunner-Disassembly-and-Stripping-Gimbal-Motor-Rewind - https://www.rcgroups.com/forums/showthread.php?1823636
Making/Modifying a replacment shaft:
Jack
Dec 27, 2017, 01:58 AM
Up&Away's Avatar
Thanks!
Dec 27, 2017, 02:04 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
Video
www.innov8tivedesigns.com
→ resources
→ video classroom
→ how to change a shaft
Vriendelijke groeten Ron
Discussion revere power plugging (futaba t9cap) YonataMor Radios 10 Apr 11, 2018 05:45 AM
Discussion Walt Mooney Boston Revere Speedster build scigs30 Free Flight 9 Apr 12, 2010 10:32 PM
Help! Motor reveres on puch out Hellysmack Mini Helis 13 Mar 30, 2008 10:00 AM
do i need normal rotation or revers rotation to use with gearbox? daltrey Electric Plane Talk 5 Dec 11, 2004 12:21 PM
Cool Looking for Books/reverence for basic building aeajr The Builders Workshop 5 Sep 25, 2003 05:58 AM
