May 07, 2018, 10:41 AM
AMA 32832 - SPA L27-VRCS 1138
Dave Swanson's Avatar
I don’t mind as long as it is Aeromaster oriented
May 07, 2018, 11:10 AM
Brighto?
Mike Denest's Avatar
Originally Posted by imodel
Here’s mine, red, white and black with red/white checkerboard on the bottom of the bottom wing and stab.
R
Looks nice Rick. What's the significance of the NC registration? http://registry.faa.gov/aircraftinqu...umberTxt=25035
May 07, 2018, 12:05 PM
deanz406
deanz406's Avatar
Hi again Dave & fellow followers- I'm still keeping up with the build and thread. I had a few pieces of original AAmco Aeromasters, 2 broken fuse, and an assortment of wings, so I took the best of all the pieces, and got this Aeromaster Too patched together, and covered. I have to install servos, tank, and motor yet, and have a Super Tigre .60 Bluehead I think I'll use. Dave, your pic of ur framed up Aeromaster is beautiful, superb craftsmanship. a couple pics- Dean
May 07, 2018, 12:55 PM
Originally Posted by deanz406
... I took the best of all the pieces, and got this Aeromaster Too patched together, and covered...
A Phoenix of sorts, then..? Looks great..! I think I'm seeing a pattern emerging concerning AM deco..!
May 07, 2018, 06:18 PM
Mike, just some excess numbers I had on hand, pure coincidence.
R
May 07, 2018, 06:27 PM
Jet_Flyer's Avatar
Dave,
If you use a film covering, I'm interested to see how you do the sunburst colors over the open wing structure.
May 18, 2018, 04:54 PM
I will start covering this weekend.
Everything lost a bit of weight during the final sanding process of course.
Weights below are for the bare balsa structure. I will weigh everything again after covering, and also after all equipment is installed.
Upper wing 8.0 oz.
Lower wing 8.9 oz.
Fuselage w/tank 27.1 oz.
Tail group 4.7 oz.
Total 48.7 oz. - 3.04 lbs.
May 19, 2018, 09:31 PM
One of the details left to do before I can start covering is fabricating the aileron servo mount.
I am using the traditional bellcrank setup and wanted the servo easily removable. This little project required over 8 hours from initial cuts in the wing to final product.
Wing has been cut out. The lower portion of the center ribs were left in place and outboard supports of the same profile are in place to support the lower ply servo mount base.
The servo upper mount base with lower base to check fitment. The lower mount base has 4-40 blind nuts.
Lower base is glued in place along the short balsa spar caps S1 and S2. The servo and upper base are now easily removable by removing the 4 4-40 x 1/4 socket head cap screws. Small washers will be used during final assembly.
May 20, 2018, 05:27 AM
Steve Merrill's Avatar
Wow, nice work. You are staying true to the original.
I flew mine yesterday about 4 flights. I added one once of lead to the tail to move my CG slightly further back. Not much different but I need almost no down stick pressure when inverted. Boy does she fly good. I also flew until the tank went dry just so would know how to set my timer, she ran out of fuel at about 11 minutes so I set my timer for 10 minute flights. Not bad for a 90 four stroke and 12 oz of fuel
May 20, 2018, 06:01 AM
Steve, I am glad to hear your enjoying the Aeromaster! Those are good flight times. We'll see how mine does with the ST60.
May 20, 2018, 06:53 AM
the smell of nitro in the morn
Wow Dave incredibly clean! Very nice.
May 21, 2018, 10:50 AM
DHG
DHG
Kinetic Sculptor
Sometimes these forums are like leafing through House Beautiful magazine ... when you get done you just want to go home & throw rocks at all your own stuff.
May 21, 2018, 05:46 PM
Quite the opposite here, I find these posts really inspirational. Not that I aspire to such giddy heights (although I do try, honestly I do ... ), but it does make me all the more careful to do the (poor...) best that I can. Keep 'em coming, please..!
May 29, 2018, 04:27 PM
I just want to go fly!
walter3rd's Avatar
what a beautiful servo install. nice
Jun 05, 2018, 02:37 PM
You got her done yet Dave?
Discussion 50th anniversary of the 737 Depronicus RC Airliners (Commercial, Cargo, Troop Carrier) 8 Apr 21, 2017 02:12 AM
Discussion Donald Campbell's daughter marks 50th anniversary of Bluebird crash AirDOGGe Dock Talk 0 Jan 04, 2017 01:04 PM
Fly-In Aug 12th Ottawa RC Club 50th Anniversary helibasher RC Flight Events 0 Aug 08, 2006 09:25 AM
Fly-In Aug 12th Ottawa RC Club 50th Anniversary Fun-Fly helibasher Fuel Power Events 0 Aug 08, 2006 09:22 AM
Discussion KC-135 50th Anniversary Celebration Majortomski Life, The Universe, and Politics 1 Jul 13, 2006 02:30 PM
