This thread is privately moderated by decreale, who may elect to delete unwanted replies.
Dec 20, 2017, 07:47 AM
L-39 Albatross
Decided to get an EDF and this one was a discontinued model. First thing I did was look at the videos on the build. Nothing overly complicated. I went about putting the jet together and then it became obvious. If the servos on the wings go bad there is no way to replace the servo. The instructions tell you to glue the wings to the Fuselage and the servo wire is inside the wing. Not on the outside. Now I need to figure out a way to resolve this before I start flying
Most likely I will replace the servos since they are garbage
Tested the servos they are crap. The esc failed to work. My advice stay away from this plane. It’s not worth the money it’s a throw away plane after so many flights
Called Horizon Hobby and they are sending another ESC. Thank you Horizon Hobby
A discontinued ESC were the reviews are horrible. If the servos do go bad the only way to replace them is to cut the wire and put an extension connector at the end of the cut wire to connect the new servo
I got the ESC from Horizon and to my surprise the ESC worked with no problems. I have not flown it yet just to cold . Waiting for the temperature to get above 45
No ventaliation so be careful not to overheat you’re batteries
I would not recommend this plane
Finally got to fly this. Was very surprised , it flew well. Lots of speed but flies well at slow speeds. Battery and ESC were not hot but I was not running at full throttle maybe 50%
Unfortunately it crashed, hand launching a jet takes a lot of effort. I tried to hand launch this and the result was total loss. I suggest you get a jet with landing gear
Discussion L-39 Albatross Kits lonewolf172 Electric Ducted Fan Jet Talk 2 Jan 02, 2006 04:11 PM
Completed L-39 Albatross Pics. My first PSS build. Z06kal Slope 23 Sep 07, 2005 01:34 PM
L-39 Albatross ashdec87 Electric Ducted Fan Jet Talk 53 Mar 15, 2004 07:49 PM
Maidened a K&A L-39 Albatross AllenS Electric Ducted Fan Jet Talk 7 Aug 30, 2003 11:24 AM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
