Jan 03, 2018, 11:46 PM
pnc
pnc
pnc's Avatar
Nice job Arron nice and thick should be good and stable for a bunch of wings ,Put me on your list please
Jan 04, 2018, 03:02 PM
Loving Lee's Slope Slut
JarheadFlyer's Avatar
Sure thing Pete... maybe we could trade some mounts?
Jan 04, 2018, 07:18 PM
pnc
pnc
pnc's Avatar
Sounds good to me
Jan 13, 2018, 06:08 PM
Gettin my polish on
So the molds are apart and the plug has been removed. Time for polish. I have identified several things I will change on the next wing mold and although these turned out far from perfect I think they will still make some pretty nice wings. Time will tell. Will polish today and make templates tomorrow and hopefully have the first wing out of the molds next weekend.
Jan 14, 2018, 04:48 PM
pnc
pnc
pnc's Avatar
Wow you move fast I still need to finish polishing my wing molds
Jan 14, 2018, 05:57 PM
It seems like it takes forever. I had some pinholes along the tailing edge that I didn't notice earlier so I have filled them in and now have to wait until it cures to continue with the sanding and polishing. In the meantime I have bagged up a new tail. New airfoil and a little smaller and thicker to hopefully make a stronger piece.
Jan 14, 2018, 08:21 PM
pnc
pnc
pnc's Avatar
As soon as this autoclave is done I'm working on the slide now so I can slide the molds in and out of it but after it's done I'm going to lay up some wings I got to build Lee and Steven a couple we will see how my old layup skills do
Jan 14, 2018, 08:56 PM
Autoclaving molds? Are they aluminum? Would like to see some pics or are you posting in another thread?
Jan 14, 2018, 11:08 PM
pnc
pnc
pnc's Avatar
With these molds ATH and epoxy,just pressure but in the near future aluminum molds as soon as I get the drawings from Steven for the fuselage of the fps I will try the tool pathing on mastercam for the first time
Jan 14, 2018, 11:26 PM
pnc
pnc
pnc's Avatar
It's just a pressure tank at this time with vaccum ports.
Jan 18, 2018, 10:39 AM
Polishing is almost complete and am now working on the layout for the internal components in the wing. Does anyone know what the hingeline for an HN 1038 airfoil is? Am thinking somewhere between 75 and 80 percent but am hoping someone has a more exact answer
Jan 18, 2018, 02:09 PM
A dream will find you
StevenSeim's Avatar
HN hinge line location...
There is no explicit hinge line location associated with HN sections Aaron. If you are thinking of the flap 'kink' associated with GT and Mark Drela, it's not there. 70-75% chord length will do you fine.
S2
Jan 18, 2018, 03:59 PM
Everything's A Compromise
Larrikin's Avatar
Personally, if this is a go-fast plane, I'd lean towards 80% just to assist in surface load and flutter reduction.
HQ sections use 78% so I reckon somewhere in that zone would be precise enough.
D.
Jan 18, 2018, 05:37 PM
Thanks for your input guys! I knew it was a wise choice to not scribe the hinge line into the plug and make it part of the mold. It wont work well at 70% with my proposed servo layout and spar location. 75% is doable, but 80% will work great.
Jan 21, 2018, 09:36 PM
Got a lot done this weekend. Finally finished polishing the molds. Waxed, PVAed, and the first set of skins is getting sucked down. Used inexpensive materials on this one and no balsa cores as I am more concerned with the fit of the patterns and the final product than I am with the weight.
I also got the new tail out of the bag and all sanded up. I got it fitted to the fuse plug for future changes to the fuse molds and I also got a plug for the rear end plug of the fuse.
Discussion CNC for Molded RC Sailplane Construction rafterrc CAD/CAM 158 Jan 03, 2019 11:06 AM
Poll New Forum Vote - Multi Task F3X Jim T. Graham Sailplane Talk 51 Jun 13, 2007 08:23 PM
Discussion Multi Task F3X Wing-span New Forum Requests 79 May 22, 2007 09:50 AM
Gallery Multi-tasking Burger Man tioli Electric Plane Talk 2 Apr 20, 2007 05:56 PM
Multi-task parkflyer? efarmer Parkflyers 1 Jun 26, 2002 02:12 PM
