Dec 19, 2017, 07:23 AM
Build Log
ATR 72-600 build ,With INDIGO airlines Livery
Hello everyone,
This gonna be my first scaled model build after lots of flitetest based and parkflyer planes,
Why ATR ?
:-huh so i needed to build some thing which is on prop's,(noob with EDF) and i love the airline company operating in INDIA (INDIGO AIRLINES),and they have recently inducted there first ATR 72-600 for dominating regional flights,
Specs:-
LEGNTH:-203.3745 cm
WINGSPAN:-203.625cm
HEIGHT:-57.375cm
expected weight :-around 4-5 kg
electronics :-UNKNOWN.
Dec 20, 2017, 02:40 AM
Airliner Builder
WAGliderGuy's Avatar
Cool project!! Subscribed
My friend and I recently built ATR42s and both of us had issues with rotating on takeoff. I recommend adding some positive incidence to the wing and maybe adding area to the horizontal stab.
Dec 20, 2017, 11:02 PM
Jaspreet Dhanjal
were you guys running counter rotating prop setup?
it would be great if you share your setup with us.. thanks
Dec 21, 2017, 06:05 PM
Airliner Builder
Yes, we used counter rotating 9 inch props with 480 sized motors on a 3S LiPo. This is more power than is needed but I wanted to install FPV gear and batteries. More details in this build thread.
Dec 23, 2017, 05:48 AM
I feel so pity for that little bird,
well Ethan i always had a look on your ATR build but i never knew that bird crashed untill you replied,
as advised i would really implement your suggestions ,
however can you please let me know on which axis did you feel the rotation?
cheer's mate
Dec 23, 2017, 05:52 AM
cheer's mate
Dec 23, 2017, 07:31 AM
Initially i have started my build from designing fuselage structure,and got messed up with whole setup,
evan a small correction and i had to change everything ,
so now i have seperated fuselage into 5 different sections,
1 nose section ,2 body section, one middle section consisting of main landing gear,wing mounts etc and at last tail section
the idea of building in parts is to replace a single small section instead of whole fuselage if incase something is needed to be changed later,
apart from this i had a big concern about the nose,as i want this to be proper scaled one even a small deviation could bring down the whole look,
so in my spare time i did a mock build with hand drawn formers out of cardboard sheets and polystyrene sheets.
find some pictures of my work done so far!
Dec 23, 2017, 11:11 PM
PROGRESS REPORT
At first started with the main bulkhead and then proceeded with mid fuselage section where the whole load is gonna act ,
here are some pictures.these whole section will run with 4 'T' shaped longerons from nose to tail!
Dec 23, 2017, 11:41 PM
Airliner Builder
Your computer work looks excellent! The problem my friend and I had was rotating the nose off the ground (vertical axis).
