Dec 19, 2017, 04:29 AM
New Product
22.2V 22000mah 25C
Big Capacity Lipo Battery
HRB 6S 22.2V 22000mah
HRB dealers wanted.
RC fans help us get dealer successfully ,HRB give you 6pcs ≤6000mah free battery.
Dec 20, 2017, 02:54 AM
jofro
What is the metric size and precise weight of this pack? Also, what are the specs for the 6S/6000/50C?
Dec 20, 2017, 06:42 AM
atreis's Avatar
They're available today on Amazon. (I have a pair of the 6s 5000 packs. Haven't used them enough to have an opinion yet though.)
Here's the link for the 6000mah 6s:
https://smile.amazon.com/dp/B06XKRWD4Z
Specs:
HRB 1PCS 6S 22.2V 6000MAH EC5 Plug with 1 year warranty and friendly customer service.
Material: Li-polymer; Cells: 6S; Voltage: 22.2V; Capacity:6000mAh; Discharge: 50C; Discharge Plug: EC5 Plug;Weight: 30.44oz
Dimension:6.10 x 1.89 x 2.17 inch. All HRB products sold by HRB POWER are comply with RoHS, CE, MSDS, UN38.3 standard.
Dec 20, 2017, 09:10 PM
6s/6000/50c
Brand HRB Battery
Capacity 6000mAh
Volts 22.2V
Cell Count 6S
Cell Configuration 6S1P
Continuous discharge rate 50C
Max Burst Rate 100C
Voltage per cell 3.7V
Max voltage per cell 4.2V
Max voltage per pack 25.2V
Suggest charge rate 1C
Wire Gauge 10 AWG Soft and Flexible Low Resistance Silicone Wire
Plug Deans Plug/XT60/EC5/Traxxas/XT90
Dimensions(LxWxH) 155x 48 x 53.6 mm / 6.10 x 1.89x 2.11 in (difference)
Weight 30.45 oz (863.3g 2g)
Certificates CE,ROHS,MSDS,UN38.3
Packing list 1x 22.2v 6000mah 50C battery
You can tell my name(Linda Lai) to customer service, they will give you some discount.
Best regards,
Dec 20, 2017, 09:14 PM
Specs:
hi Atreis, thanks for your share.
Could you tell me your Amazon ID?
When you order next time, I will tell our Amazon customer service give you a little discount.
Dec 21, 2017, 02:14 AM
jofro
Have you got specks on that larger 22Ah 6S pack? Dimensions and weight? TX.
Dec 21, 2017, 10:04 PM
22000mah 6S
Brand: HRB Battery
Capacity: 22000mAh
Volts: 22.2V
Cell Count: 6S
Continuous discharge rate: 25C
Max Burst Rate: 50C
Voltage per cell: 3.7V
Max voltage per cell: 4.2V
Max voltage per pack: 25.2V
Suggest charge rate: 1C
Wire Gauge: 10 AWG Soft and Flexible Low Resistance Silicone Wire
Plug: Deans Plug/XT60/EC5/Traxxas
Dimensions(LxWxH): 198 x 90 x 66 mm(0-3mm difference)
Weight: 93.1 oz (2640g 2g)
Certificates: CE,ROHS,MSDS,UN38.3
How many you need?
Dec 22, 2017, 06:38 PM
jofro
Originally Posted by Yowoo Linda
Brand: HRB Battery
Capacity: 22000mAh
Volts: 22.2V
Cell Count: 6S
Max Burst Rate: 50C
How many you need?
Thanks for the info, I highly recommend you ask your supplier to upgrade the power leads to "8 G", also, I would like to see higher C rating for this set.
I use various brands of 6S large capacity packs in 12S/8-12 Ah configuration to power some of my large EDF fleet with currents well over 200 amps and 10+ Kwatt outputs, so this large 22Ah set hooked in series could make the thing easier while using only 2 packs instead 4 to minimize connections.
PM me if interested, I can test the set for you in my models. Happy Xmas, Cheers.
Dec 25, 2017, 12:57 AM
We can do the 22000mah lipo use 8awg.
but the C rating is 25C.
do you need test one pirce?
Dec 26, 2017, 04:24 AM
jofro
I would need for tests two batteries connected in series as 12S/22Ah.
Dec 27, 2017, 01:57 AM
custom-make 12S 22000mah
could you tell us your requirements?
We can custom-make the battery.
We have own factory in Shenzhen.
Could you tell me your whatsapp, skype or email?
My email is yowoo2022@yahoo.com
whatsapp: 008615814788262
Skype: linda19920426
Dec 29, 2017, 03:58 AM
jofro
Many Tx for the reply, email sent, Cheers, J.
Dec 29, 2017, 04:20 AM
thanks
I got your email.
Thanks very much.
Dec 29, 2017, 10:36 AM
Jerm357's Avatar
If your looking for dealers, I would try GetFPV.com, ReadyMadeRC.com or AloftHobbies.com. They are some of the best online shops in the hobby.
Jan 02, 2018, 01:41 AM
Thanks friend
Thanks your share.
If you order our lipo, we can give you a little discount.
New Product JackPower 22.2V 25C lipoly intro special mtnflyer44 Electric Heli Talk 3 Aug 31, 2008 11:01 AM
