Prop in slot XB-70 - RC Groups
Dec 18, 2017, 12:27 PM
Build Log
Prop in slot XB-70
A while ago I made a prop in slot XB-70 Valkyrie out of dollar tree foam board. I have looked around but wasn't able to find pictures or videos of other people doing this except for the Nico Hobbies XB-70, so unless someone proves me wrong, I am officially taking the title of "Creator of the first scratchbuilt prop in slot XB-70 documented on the internet". Unfortunately I crashed my first Valkyrie into a tree on the maiden, and it was destroyed. After putting RC on the back burner for a few months (due to a different crash) I saw this one post by softshell29 about his build of a massive balsa XB-70, and that really inspired me to bring my simple Valkyrie back.
A few days ago I got some more foam and started drawing the parts out. I started with the wings, and then drew out the parts for the undercarriage, canards, vertical stabs, and a few other parts that I could fit on the sheet. I am currently working on drawing the neck, fuselage, and nose on my third sheet. I should be able to finish today if I don't get caught up in other things.
Here's the link to softshell29's post: https://goo.gl/8mYRJa
I'll edit this post to include pictures when I get home.
Dec 18, 2017, 06:11 PM
Kimbers Keeper.
BHOFM's Avatar
I, a friend and I have talked about doing one for some time, If you check the bottom of the page
there is a balsa prop slot XB-70 thread.
I have a high resolution three view I am going to use for plans. It will be a twin pusher though.
I did a SST early in the summer, it is a great flier. 2lbs, 600W. 2700kv motors.
I may use the same setup on the XB. Two 3s 1300 gives almost ten minutes flight time.
Don't have a pic when it was finished. Added windows and some other stuff.
I don't think I will do a thread on mine, I get little or no response. I end up locking the thread
when it gets to page 5.
Finished pic's.
Dec 18, 2017, 07:30 PM
Kimbers Keeper.
BHOFM's Avatar
How are you going to stiffen the wing where the prop slot is? The lower fuselage sides need to run
full length. The best answer is a smaller prop and more KV.
Dec 18, 2017, 10:32 PM
loonsmock's Avatar
Ooooh, I love the XB-70! I might just give this one a go, as my current scratchbuild project has not been going well and I could use a change of pace. Keen to see more! Also, do you recall what electronics setup your original one flew on?
Dec 19, 2017, 12:21 AM
In short, the ft power pack c. More specifically, it ran a emax gt2215 1180 kv motor, 30 amp esc, and an 1800mah 3s battery, as well as two 9 gram servos and a 6ch rx.
Dec 19, 2017, 12:22 AM
On the original I had some om BBQ skewers implanted in the wing perpendicular to the slot that acted as spars. Maybe not the best but better than nothing.
Dec 19, 2017, 12:26 AM
Here's what I was able to cut out tonight. The nose/fuselage, the neck, and one of the supports for the undercarriage. Tomorrow I'll tackle the undercarriage, some of the stabs, and i might have some got glue by then so I might start gluing the parts together.
Dec 19, 2017, 08:05 AM
Captain Dunsel's Avatar
I think you're talking about my prop-in-a-slot XB-70. Yes, it was all wood, which is why it was heavier -- too heavy to fly well. If I ever get around to it, I'll do another one, but made from foam and not wood.
Oske, I don't know if this will help you, but let me tell you what happened with the two XB-70's I built.
The big problem I ran into was a LARGE shift in the CG when going a prop-in-a-slot to a full winged pusher. The CG moved forward several inches, so the pusher was terribly tail-heavy at the same CG location. I moved the battery to just behind the canards and (sacrilege, I know) added long extensions between the ESC and the motor AND between the ESC and the battery. It still was a handful and barely survived it's only flight (which ended in light damage from a stall/spin from about 10 feet). After the one flight, I decided not to pursue the project.
Break a leg, Oske!
CD
Dec 20, 2017, 08:10 PM
Kimbers Keeper.
BHOFM's Avatar
Mine is almost done, waiting on the motor, esc, prop. Fri, Sat, maybe.
Dec 20, 2017, 10:45 PM
Going back to balsa
Mine is almost done...
Incredible! You are an interesting guy BH.
PS - I hope that it will fly great.
Dec 20, 2017, 10:59 PM
Got all the parts cut out, got some glue, and I've got 2 weeks off to work on this project.
Dec 21, 2017, 02:32 AM
Been a productive night. Got most of the parts glued together. Still need to glue the fuse to the wings, attach elevons and stabs, get the electronics worked out, and a few other things. For now, that's enough for tonight. I'll probably be able to finish it within the next few days and might make a video on it.
Dec 21, 2017, 09:25 AM
Kimbers Keeper.
BHOFM's Avatar
Looks bigger than mine? Span? Mine is 32"X60". Just a bit longer than the SST.
Looks good, like the wind screen.
Dec 21, 2017, 03:08 PM
surprisingly, the span on mine is 35x30", but about 35x50" if you include the length of the fuselage. Also thanks, i tried to make the new nose more realistic, the old one looked like something out of a cartoon.
Build Log B-70 Project.......RC XB-70 softshell29 Giant Electric Planes 555 Apr 28, 2018 12:18 AM
Build Log XB-70 Prop in a Slot Captain Dunsel Pusher Prop Jet Models 57 Nov 16, 2016 02:48 PM
Discussion Videos: Hollywood Goes to War,XB-70,WW2 Test Pilots,JG 26,75mm B-25s & more zeno General Aviation 0 Nov 11, 2015 11:05 AM
Discussion Videos: Hollywood Goes to War,XB-70,WW2 Test Pilots,JG 26,75mm B-25s & more zeno General Aviation 0 Nov 11, 2015 11:00 AM
Discussion XB-70 xb 70 Valkyrie Ted61 Giant Electric Planes 1 Jul 23, 2008 01:48 PM
