What prop and motor should I use? - RC Groups
Dec 17, 2017, 11:58 AM
I have the stock 3536-KV850 motor with the 11X6 3 blade prop. I want to soup it up so it goes faster and so it will fly better with a 100 gram camera mounted on top.
I was thinking a 25 power 1250Kv motor with a 10.5 x 7 prop 3 blade. But I'm probably wrong and that would just ruin the motor and esc..
Does anyone have any suggestions before I do something stupid? I don't know much about power systems but I want to learn as much as I can.
Plane Weight: 1520 grams, 56 oz, 3.4 Lbs
Model: 1410mm FMS sky trainer 182
If anyone can help, THANK YOU!
ps. The 11X6 stock propeller is big, only about an inch from the ground, and I've broken 3 already from bouncy landings.. Could I use a higher kv motor with a slightly smaller prop and still get more power?
Dec 26, 2017, 07:11 AM
You might wish to play with the figures in this calculator, it's useful for comparison purposes.
Question OS 160 glow What prop should I Use? n1832y Fuel Plane Talk 16 Dec 24, 2016 06:37 PM
Discussion What prop should I use? Remotecontrolkid Racing Boats - Electric 3 Aug 31, 2016 10:29 PM
Discussion What prop should I use? Remotecontrolkid Dock Talk 1 Aug 31, 2016 09:36 PM
Question what motor/battery should I use? Jacktstone Foamies (Scratchbuilt) 1 Jun 28, 2016 08:29 PM
