Skin modeling with foam sheets - Page 4 - RC Groups
Jan 01, 2018, 07:21 PM
osern's Avatar
sculpt the detail on surface
I use a pencil to scribe contour of canon guns at the end of nose cone on the surface, Depron will get dent or squeeze to bump up with pencil tip pressing with tilting or rubbing.
I shape slightly bump out stuff, panel lines, original U-shape cheat holes on F-18 fuselage and stick outs( signal lights?) on vertical rudder fin .
Jan 09, 2018, 09:45 PM
osern's Avatar
Identical from a template
The fascinating thing of skin modeling is that you can easily duplicate model from a template,construct identical stuff and parts,
I don't care if it crash or not rigid enough,the replacement parts are unlimited in hands.
Build log for detail https://www.rcgroups.com/forums/show...5mmEDF-F-A-18E
Jan 11, 2018, 05:41 PM
G G Ghost Pirates !!!
Vyceroy's Avatar
i dont see anything different than what we have been doing here for over 15 years ..
Jan 11, 2018, 06:50 PM
treefinder
springer's Avatar
Sortof, but there's a "generation " of FT kit and design builders who need reintroduction to the finer sculpting, and I gotta admit that osern is a master sculptor.
Jan 11, 2018, 06:58 PM
Vyceroy's Avatar
i didnt mean to sound like a douche but it came out that way .. yes he is a fantastic sculptor and i do need to acknowledge that ..there is some awesome stuff he has done and i would like to work with him in the future on a project .. once again my sincere apologies .. I did not mean to take away from his fantastic work ..
Jan 11, 2018, 07:01 PM
serial scratchbuilder
Granted's Avatar
Correct. What you see here is someone that does it very, very well.
Kudos to the OP.
Jan 11, 2018, 09:15 PM
treefinder
springer's Avatar
But I think we can also agree that there are a flock of guys who joined the hobby through flite test and their flat paper on construction techniques some of which will grow beyond that if shown how. And this thread gives great teaching on how!
Jan 12, 2018, 07:14 AM
osern's Avatar
Thanks for the comments.
Welcome to post any ideas and works here,it's a great hobby to build and fly,it's healthy to share!
Some time it's a conflict to commercial deals,if every one build their own models,they'll be panic!
Truth is this method also help to repair and patch up damaged prefabricated models that help people willing to buy more their products without fear of crashing their expensive investments,they should think again. to help promoting.
Still it's crucial to make it build model easily to attract new ones joining this hobby,Fltetest is doing right things to promote.
I hope this thread also could help to build models as easy and scale as possible at the same time for every one,let it be a preciatiable model and a flyable model to accomplish childhood dreams.
Jan 12, 2018, 08:15 AM
osern's Avatar
thin and firm joint edges
Chamfered edges not only increase contact area for adhesive to glue more firmly but also make minimum uneven joint edge for sanding,sometimes there is no need to sand or trim when they flow along panel lines that are almost invisible.
This is also useful to patching up damages of purchased foam models that are unable to resonate with hot water soaking .
Jan 18, 2018, 09:12 AM
osern's Avatar
Su-35 is a tough one to bend as one piece.
Hot glue gun forming for concave surface failed when scribe lines dense too deep that they'll shrink and get thin-ed with melting.
It needs to bend with more accurate curve flow on the back side and with just enough pressure and less uncertain beding.
It's difficult ,I have to admit that.
Jan 18, 2018, 11:21 AM
Klutzsquatch
mgroves's Avatar
UMX Size De Havilland Beaver
Looking for this to go to a good home.....see link below
https://www.rcgroups.com/forums/show...r#post39009380
Jan 18, 2018, 06:31 PM
osern's Avatar
Quite a floaty sample for beginners.
Jan 25, 2018, 02:19 PM
osern's Avatar
There are some things about SU-35.
Jan 31, 2018, 06:31 AM
osern's Avatar
It turns out that the concave curve surfaces are with acceptable smoothness by the aid of tape covered and light blue scheme paint.
I like this blue Israel scheme with a lot of white.
There is no use for sparkle and sanding on tapered surface,it gets round and smooth naturally with hot glue gun ironing.
Feb 01, 2018, 08:00 AM
Thomas Nelson's Avatar
Very nice job of the concave area!
tn
New Product Future Model 38" scale Edge with awesome PP airframe skin. MORE VIDEOS ADDED! groovejet 3D Foamies 897 Jul 14, 2018 02:20 PM
New Product Future Model 47" scale Edge with same awesome stiff skin as 38" version - NEW VIDEOS groovejet 3D Foamies 94 Apr 26, 2018 09:47 PM
New Product Future Model 38" scale Slick with awesome PP airframe skin. PP Planes Rock! groovejet 3D Foamies 27 Oct 14, 2017 12:45 PM
Help! Need to find :Depron built up wing with depron ribs and skin thread Turbopropdrive Scratchbuilt Indoor and Micro Models 5 Nov 06, 2012 05:34 PM
