Question
PowerLab 6, 1s high voltage charging
I just purchased the cable to update the software on my PL6 so that I could have access to the high voltage settings so that I could charge the new high voltage lipos i purchased for my tinywhoop.
However, It appears that the 1s no-balance option does not allow you to configure a voltage higher than 4.2 volts. Is it possible to charge 1s's up to the high voltage standard on PL6? A quick search of this forum did not find an answer. Thanks, |
Right now the only way to use the high voltage preset is through balance charging as there is not one for non-balance. Howard |
Is there another solution in the meantime? I also need to charge small 1s HV lipos on a PL8. I can think of some series adapter configurations to charge them like a multiple cell pack, but would rather avoid yet another adapter. |
I purchased one of these: https://www.amainhobbies.com/protek-...k-5332/p424734
Then added a 2s balance tap to it (using only 2 of the 3 wires) . since both the balance and power taps are connected, you can use the standard HV settings. Its a bit clumsy seeing as I'm going PL6 -> PL6 parallel board -> 1s parallel board, but it works. |
Soldered up a pair of single cell pigtails cut off a "squid" parallel cable and soldered them to a 2s balance plug and JST power lead. Allows me to charge 2 cells as a 2s pack connected to the MPA-XH-PL
My PL8 does not have a HV preset. I had to create one. Ah! Charger just beeped finished and nothing caught fire. Looks like it works ![]() |
Thread Tools | |
Similar Threads | |||||
Discussion | Charging 1s HV lipo on powerlab 6 help | revhappy | FMA Direct | 4 | Feb 20, 2017 03:10 PM |
Help! | Powerlab 6 and Li-ion Charging | Rich__B | FMA Direct | 4 | Feb 02, 2016 08:55 AM |
Discussion | Powerlab 6 multiple 1s charging | overthebars | FMA Direct | 3 | Mar 16, 2015 05:20 PM |
Question | PowerLab 6 charge voltage not available | TomHudson | FMA Direct | 4 | Oct 31, 2012 05:51 PM |
Question | PowerLab 8 parallel 1S "balanced" charging | ibrandt | FMA Direct | 1 | Apr 11, 2012 04:53 AM |
