Dec 14, 2017, 07:06 PM
DeadStix
H9 Carbon Cub 90”. Electric?
Going to build Carbon Cub. Would like to install Rimfire 120. Anyone done this? Advice?
Dec 14, 2017, 10:00 PM
scirocco's Avatar
A clubmate has the Carbon Cub with the H9 recommended Eflite Power 60B, 470 rpm/V, which is very similar in weight and Kv to the Rimfire 120. Running 16x10 on 6s 5000 it has lots of reserve power - performs really nicely. So the R120 will be a good solution.
Only downside is shortish flight times on the 6s 5000mAh , but that is easily solved by just adding a second pack in parallel - no balcony or access issues to do so.
Dec 15, 2017, 02:46 PM
...design-build-fly-publish...
eye4wings's Avatar
The only problem with doubling the pack is that you also double the weight and make the model less forgiving.
6S means motor is running on 24V and will turn close to 11,000 RPM.
with a x10" prop wash will be 84.5 MPH or thereabouts.
Little wonder flight times aren't long!
Just how heavy is the built model likely to be?
15x8 wooden prop would probably be a good median that would win back some of the lacking flight time.
Save the second pack for a second flight.
But it's always worth making every attempt to build the airframe as light as possible and power it accordingly. That way you get a much nicer flying model.
Have fun building!
Robin
Dec 16, 2017, 08:18 AM
ARFs Are Me
TomCrump's Avatar
Robin
Most Cubs of this size, should easily handle the extra weight. I doubt that added weight would be an issue, here.
Jan 01, 2018, 09:07 PM
vollrathd's Avatar
Yeah
Back in the late 1990's, I built a 1/4 scale Cub from a kit. Never saw so many pieces in my life. Wingspan was some 120 inches, it flew with a brush type Astroflight geared 90 motor with a home made gear box. It turned a 20X10 prop at some 5000 RPM, pulling around 800 Watts. The model flew with 38 RC2400 NiCad cells that weighed a ton and a half.
Take off runs were around 50 feet, it flew like a Cub. It would do loops and rolls, just like the full scale Cub. You had to dive first to loop it. Now days, I've got a 4500 Watt brushless setup in my giant PeakRC Corvus where this motor and battery system weighs less than that Astroflight motor and battery pack. And, both have about the same flying time.
Jan 08, 2018, 11:16 PM
One more flight...
CashD's Avatar
Mine is on floats and has an Axi 4130-16 /385 kv) running on 5800 6s. I have an apc 16x10 on it.
Jan 23, 2018, 06:56 PM
Flying again - 4th time
FOGeologist's Avatar
I'm flying mine on 18x8 wooden prop, 8s, 80/90 amp ESC, two 5500 mAh 4s in series.
Jan 30, 2018, 12:55 PM
What flight times are you guys getting on your Cub? and what style of flying?
MY friend just got this ARF and we like to know.
I fly my Phoenix Models 90" Super cub on 7S, 5000 Mah, 295KV and I get about 5-6 min of normal flying, a few touch and goes but not much full throttle flying. Land with about 36-40% left, 3.8-3.87V per cell....FYI...
Feb 01, 2018, 03:34 PM
FOGeologist,
What motor are you using?
Feb 01, 2018, 05:06 PM
It is a Turnigy 160, Can't recall nor see its Size thru the cowl, threw away the box....
Feb 08, 2018, 12:37 PM
My buddy built this with a Scorpion 4025-440kv. This motor is very similar performance to the recommended eFlight Power 60 (actually a bit more powerful) , but is very disappointed in the performance.. We’re looking for something with more power.
May 03, 2018, 11:00 AM
Mine got a Hacker A60-6xs v2 with a Xoar 20*13
getting power from a 7s4p Li-Ion battery... 24V, 12Ah
Aug 24, 2018, 02:09 PM
Mine has the E - flite 60 with 6s 4400 , flys great was flown on floats performance is great,
We sometimes think to much
Sep 17, 2018, 10:39 AM
You might get what you pay for
Prodrvr's Avatar
Which prop are you using?
Discussion H9 Carbon Cub 15cc Engine choices bc1960 Giant Scale Airplanes 0 Aug 23, 2017 05:12 AM
Discussion Electric Space Walker - From Carbon Z Cub Electrics bluespier Electric Plane Talk 1 Oct 18, 2016 08:06 AM
Discussion Carbon Cub 15cc vs Phoenix Model® Super Cub PA-18 90.5" GassPasser Giant Scale Airplanes 4 Oct 16, 2016 07:40 PM
Video H9 Electric J3 Cub with Canon IXUS 70 on board Stuart Warne Electric Plane Talk 14 Mar 17, 2009 06:13 AM
Question H9 CUB Glow to Electric HUNT Glow to Electric Conversions 4 Oct 21, 2006 12:37 AM
