H-King Teksumo EPP Combat Wing - RC Groups
You might be familiar with the Teksumo EPP wings, but H-King as has made a few changes to the 900mm wing that makes it a versatile wing at a great price of just $49.36.
Versatile Flying Wing
You might be familiar with the Teksumo EPP wings, but H-King as has made a few changes to the 900mm wing that makes it a versatile wing at a great price of just $49.36. They've included an FPV camera mount so you can attach a cam/tx combo for easy fun FPV flying. It now includes a carbon fiber motor mount which is more durable than before to handle rough landings. The pushrods are 3mm hardened steel for better control with less flex.
The Teksumo comes as a kit that's easy to build with just a few glue joints. You can get it in 4 different color schemes and all up the model weighs in around 300-350g. You'll need to supply your own power system, servos, and radio system to get it ready for flight.
Check out the H-King Teksumo EPP Combat Wings here
Specifications:
  • Wingspan: 900mm
  • Length: 575mm
  • Flying Weight: 300~350g
Requires:
  • 4 Channel TX/RX with delta mixing
  • 2 x Metal gear 9g Servos
  • 1 x 40A ESC
  • Mild Setup: 2208-1370KV Motor, 6x5 Prop, 3S 1500mAh 30~35C Battery
  • Hot Setup: D2826/2200KV Motor, 6x4 Prop, 4S 2200mAh 30~35C Battery
  • FPV Gear (optional)
Dec 13, 2017, 05:08 PM
Professional UAV Services
Redemptioner's Avatar
Great updates for a great little wing
Dec 14, 2017, 12:32 PM
twice the price of the old one now
The older revision is now 22 (euro?) compared to the price of the new ones.
Doubt the changes are worth twice the price so ordered 3 of the old kits as backup.
Dec 22, 2017, 07:20 PM
I got mine today and no instructions. I figured it out and built it in a couple hours. Using the CG from the older version instructions that were online. Hopefully test fly after Christmas
Dec 26, 2017, 05:27 PM
Looking for where cg is as no instructions
Dec 26, 2017, 09:19 PM
Is the material any different? The old teks had a poor quality foam, especially when compared to the VAS products.
Dec 29, 2017, 05:42 AM
Foam is ok bends lot i added lot more carbon strips and going to laminate
Still waiting for manual for cg
Jan 04, 2018, 01:42 PM
Team WarpSquad
JoeMama's Avatar
I glued the halves together and plan to laminate mine. I like the CF motor mount. Do you guys know if you can really fly them with the recommended battery set up.
I have a pop wing sport that is about the same size and was really disappointed with the recommended set up compared to what I ended up with to get it to balance and fly. I had to move the battery forward and go a lot larger. I love how it flys now but I would like to set up this new tech sumo for my son and would benefit from a light build as he still has a lot of impactful landings.
News H-King Glue-N-Go Clownfish and Blue Tang EPP 850mm Kits Jason Cole Foamies (Kits) 111 Dec 18, 2017 10:19 AM
News H-King Glue-N-Go Series EPP Shark Jason Cole Electric Plane Talk 10 Oct 03, 2017 11:19 AM
Article H-King Wargo YAK 55 EPP KIT Jason Cole 3D Foamies 11 Sep 21, 2017 10:44 AM
Discussion Foamworks Combat EPP P-51 Park Flyer CalvaryStudy Electric Plane Talk 6 Nov 17, 2015 01:19 AM
Discussion 3450 kv motor on a Teksumo EPP Wing? feerof Beginner Training Area (Aircraft-Electric) 12 Sep 14, 2013 02:46 AM
