Dec 12, 2017, 12:25 PM
hog2soar's Avatar
Build Log
Scratch build 1.2m balsa build-up Polyhedral Experiment
I was bored and waiting for my hip to get better (pulled muscle or something....painful) so I decided to experiment and build a balsa build-up polyhedral 1.2m DLG, for fun. I named it XP-1 for experimental plane one. I hand drew up a plan and plotted some AG-12 airfoil ribs for fun just to see what would happen. Originally I was going to make it a flapperon model, then changed my mind. When you get old your allowed to do that. I scratch built the fuselage based on the Falke fuselage, then fiberglassed it and painted it. If and when my hip gets better I'll maiden it. It's a bit of a porker as its auw is 10.5 ounces. If it launches and flies half way decent I'll build another one and be a little more careful with the build and I'm sure I can drop an ounce or two. I may even add flaps. Anyway here's some pictures. I'm not real happy with the covering or the colors. I used what I had on hand from other projects.
Enjoy, or don't
Eddie
Dec 12, 2017, 12:42 PM
hog2soar's Avatar
More pictures
Continuing and making it a polyhedral. I got a little carried away trying to stiffen it up and that's what added the weight. I ended up cutting come carbon spar braces for the poly breaks and fiber glassing the joints. Then like a dummy I added diagonal braces (more weight). Anyway, here it is.
Dec 12, 2017, 04:23 PM
Transplant Chey WY from Reno
Thermaln2's Avatar
Very nice Eddie!
Dec 12, 2017, 04:52 PM
New at this whole life thing
Cfiimei's Avatar
I bet it flies great!
Build Log Wanderer scratch build - balsa build log zarqeon Balsa Builders 111 Apr 08, 2018 06:20 PM
Discussion 1.25m Balsa build up DLG (Streched Spinnin' Birdy) MadMatt986 Hand Launch 3 Oct 02, 2017 12:25 PM
Discussion "Stretching" a 1m balsa skin build up to 1.2m? MadMatt986 Hand Launch 5 Sep 08, 2017 06:11 PM
Build Log 2m Boeing 757-200 depron + blue foam scratch build RCExplorerUK Foamies (Scratchbuilt) 2 Aug 01, 2016 08:32 AM
Build Log Something really different...Scratch build 2M Vintage style sailplane (Glider) hog2soar Thermal 18 Nov 10, 2015 12:36 AM
