Dec 12, 2017, 09:38 AM
New Product
​ 32" YAK 55 with full fuse - replace your profile foamy
How do you feel about profile indoor foamies? Well, I love to fly them as well.
It's easy to build, repair and provides you an opportunity to learn 3D maneuvers fast.
Our YAK55 provides you all these benefits along with another feature - full round fuze.
It changes the way the plane flights. You will get rid of the extensive knife edge stability that all the profile foamies have to make your plane feel like an indoor trainer of a large aerobatics machine.
Now, the best part.
The plane designed to fit your regular electronics from a profile foamy, so no extra investments.
Technical data:
Lenth - 800mm
Wingspan - 800mm (~ 32')
Frame weight ~ 65g or less
Flying weight ~ 130-150g
It can run on the Turnigy/AXI 2204 20g outrunner, requires two 5g servos and one 9g for ailerons and the 350-500mAh 2s lipo.
Building log:
The Fuse part 1 - https://www.rcgroups.com/forums/show...75&postcount=4
The Fuse part 2 + Horisontal Stabiliser - https://www.rcgroups.com/forums/show...64&postcount=7
The Fuse part 3 - https://www.rcgroups.com/forums/show...4&postcount=15
The Fin - https://www.rcgroups.com/forums/show...67&postcount=8
The Wing part 1 - https://www.rcgroups.com/forums/show...1&postcount=10
The Wing part 2 - https://www.rcgroups.com/forums/show...5&postcount=22
The Canopy - https://www.rcgroups.com/forums/show...36&postcount=5
The Control Horns - https://www.rcgroups.com/forums/show...1&postcount=18
The Aileron Servo setup - https://www.rcgroups.com/forums/show...8&postcount=19
The Tail Servos setup - https://www.rcgroups.com/forums/show...2&postcount=23
The Cowl - https://www.rcgroups.com/forums/show...8&postcount=24
The Service Door - https://www.rcgroups.com/forums/show...4&postcount=26
If you are interested in pre-ordering the KIT, welcome here http://prettyfoam.bigcartel.com/prod...e-yak-55-800mm
Stay tuned, will be posting some building and flying pictures soon.
Dec 14, 2017, 01:06 PM
Soar high, huck low
electrich's Avatar
Flight video?
Latest blog entry: Super sized Delta combat wing
Dec 16, 2017, 09:58 AM
Comming soon.
The weather is not very nice these days and I prefer to fly outside.
Dec 24, 2017, 05:08 AM
Well, let me show some building pictures, starting from the fuse.
Dec 27, 2017, 01:23 PM
Let's move on.
Now, the canopy.
I recorded a simple video building it.
Yak 55 Canopy build video (7 min 8 sec)
As I used the contact glue, I left the canopy in this position for 24 hours. After, carefully removed the tape.
Dec 31, 2017, 06:24 AM
You asked for flight video. Here you are
Full Fuse Yak55 - last flight of 2017 (2 min 22 sec)
Folloving up with some flying pics from this day and some other one.
Jan 12, 2018, 10:04 AM
BryanEW710's Avatar
Interesting.
Jan 14, 2018, 05:33 AM
Originally Posted by BryanEW710
Interesting.
Nice)
I'll continue then...
All I need to do with the wing is connect 2 parts of it together and reinforce the LE and TE with the 3*0.2/0.3/0.5 mm CF strip
Jan 14, 2018, 06:27 AM
BryanEW710's Avatar
What kind of foam is that?
Jan 14, 2018, 01:17 PM
It's almost like depron but used mostly for the building needs.
I'm testing the KIT using this foam and after wish to build the same from the EPP.
So far I love how it feels and flies, but requires a calm weather, zero wind is perfect...
Jan 14, 2018, 01:30 PM
BryanEW710's Avatar
I was curious because I know Depron supplies are starting to run out.
Jan 16, 2018, 05:59 AM
In our area we have no depron suppliers at all. So have to look for alternatives
Discussion Foam YAK 55 with full fuze shastnyy Indoor Pattern/F3P 5 Nov 20, 2017 11:43 AM
Build Log Full fuse Sukhoi SU-26MX based on the 3D Foamy Profile ukdalai Foamies (Scratchbuilt) 4 Nov 29, 2010 07:32 AM
Discussion Full Fuse Yak 55? MATTS650 Foamies (Scratchbuilt) 2 Oct 22, 2009 03:12 PM
Build Log Got parts from Hobby Lobby Yak 55, lets build a full fuse Yak 55 Lampatex Foamies (Scratchbuilt) 16 Jun 13, 2007 10:50 AM
Insane Foamies Full Fuse Yak-54 build and fly thread! j_z_123 3D Flying 52 Aug 20, 2005 09:48 PM
