This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Dec 09, 2017, 06:57 PM
old4570's Avatar
Mini-HowTo
A quick update on the XK X6 Tx and binding it
Ok , I bound the XK X6 transmitter to a futaba Rx micro quad ...
A lot of folks might wonder just how you would go about that when the Tx has no bind button .
Apparently the XK transmitters go through a quick bind process when you turn them on .. ( remember this )
So take your Rx , and get it into bind mode .
Then turn on the X6 or X7 transmitter .
As the transmitter boots it will go through its bind process and bind with your Rx .
Turn of the Rx and turn of your X6 / X7 transmitter ..
Now you have to turn on the Rx first , then the Tx just like with a lot of micro quads N stuff ..
If you turn on the Tx first , you will not get a bind . ( Because the Tx needs to go through its bind process on starting )
So there .. ( Hope this helps )
Jun 03, 2018, 08:49 AM
Xk a600 bind new plane to old transmitter
Hi I've had a bit f trouble with my xk600 so buying a new one but I don't need to buy a transmitter how does it bind toriginal transmitter
Jun 03, 2018, 06:53 PM
old4570's Avatar
Does the model have a bind button ?
My XK110 has a bind button , so pretty much the same way as described
Discussion updated to latest open tx on taranis - no longer works as controller in simulator? lyons238 Multirotor Drone Electronics 8 Apr 24, 2017 08:29 PM
Discussion XK X6 or X7 TX: mod to add 3-position switch? dronebrulee Mini Multirotor Drones 2 Jan 09, 2017 12:35 PM
Help! tx binded but no input on cleanflight rps13sr Beginner Multirotor Drones 4 Nov 23, 2015 10:39 PM
Question XK X6 transmitter range? gggsmith Micro Helis 1 Oct 24, 2015 02:32 AM
